ᐅ Multi-Utility Entry: Yes or No?
Created on: 9 Sep 2020 13:50
SebastianH.
SebastianH.
9 Sep 2020 13:50
this topic has already been discussed in the forum. However, I still cannot form a final opinion on it. Does a manifold system (MSH) really make sense or not? The alternative would be, for example, using PVC pipes in the basement, right? In the end, it all comes down to the same thing, or what is the added value of a manifold system? From there, the supply still needs to be distributed to the rest of the house anyway!?
Regards, SebastianH
lastdrop9 Sep 2020 13:52
What does the utility provider require?
SebastianH.
9 Sep 2020 14:04
lastdrop schrieb:
What does the utility company require?
Nothing. The construction company asked us if they should include this, since it would incur additional costs. Now I wanted to find out whether it makes sense for us or not.
T_im_Norden
9 Sep 2020 15:16
I find them practical, well sealed, and easily accessible.
When planning, just make sure there is enough space on the wall and, if necessary, divide them into pipe groups.
SebastianH.
9 Sep 2020 15:20
T_im_Norden schrieb:
I find them practical, nicely sealed, and easily accessible.
Just make sure there is enough space on the wall during planning and, if necessary, divide into pipe groups.
Isn't that the case with PVC pipes as well? And what do you mean by pipe groups?
T_im_Norden
9 Sep 2020 15:37
MSPs are increasingly required by more utility providers for good reason.
The pipes either come with pre-fitted, custom seals, or the seals are partially integrated into the pipes themselves. This ensures gas and water tightness.
MSPs are usually configured in groups of four. Because space in technical or utility rooms is often very limited, installers frequently have difficulties fitting the connections or meters. In such cases, it can be advantageous to use two MSPs with two inlets each and install them on different walls, for example, on the left and right sides of the utility room door.
