ᐅ The Malm nightstand wobbles due to loose screws – how can I properly tighten them?
Created on: 7 Jun 2022 18:27
Harry39
Harry39
7 Jun 2022 18:27
Hello everyone, I have a Malm nightstand from IKEA that is unfortunately wobbly because one or more screws are obviously loose. Now I want to secure the screws properly again so that everything is stable and secure. However, I am wondering what the best way to do this is without damaging the material or the piece of furniture. Are there specific techniques or tools that should be used for the typical joints in Malm furniture? And what exactly should I pay attention to when tightening the screws to avoid over-tightening or the screws becoming loose again? I would appreciate any tips and experiences!
Tinaneo
7 Jun 2022 19:36
Harry39 schrieb:
I’m wondering how to best secure loose screws on a Malm nightstand without damaging the furniture.
First of all, it’s important to identify whether the loose screws are for joints or shelf pins. Malm furniture often uses cam lock connectors, which can wear out after repeated loosening and tightening.
A reliable method is to carefully loosen the screws, possibly disassemble the joint completely, and then retighten the screws gently. I recommend using a torque screwdriver or, at least, a screwdriver operated with a light touch to avoid over-tightening.
Harry39 schrieb:
Are there specific techniques or tools that should be used on the typical connection points of Malm?
Yes, a hex key (Allen wrench) or the special tool provided is usually best. Sometimes it also helps to apply a small amount of lubricant (such as graphite powder, never oil) to the screws before retightening to reduce friction.
Harry39 schrieb:
What should I watch out for to avoid over-tightening or having the screws loosen again?
This is crucial: excessive torque can damage the threads. To prevent screws from loosening after tightening, you can apply a small amount of medium-strength threadlocker (not a permanent adhesive). This works well for furniture joints as well.
Finally, I would check if the screw holes in the wood are still intact. If not, special wood dowel glue or even a wood thread repair kit can help secure the screws firmly and durably.
rigau
8 Jun 2022 07:42
Loose screws on the Malm nightstand can be simply tightened with a suitable Allen key.
If the thread or hole in the wood is damaged, repair it using wood glue and, if necessary, a small piece of wood.
Do not overtighten to avoid causing damage.
lalutau
9 Jun 2022 09:55
Tinaneo schrieb:
One way to prevent loosening is to apply a small amount of medium-strength threadlocker after tightening.
That’s a good tip I’d like to add to: Medium-strength threadlocker, such as Loctite 243, is ideal because it securely holds the screws while still allowing future retightening or removal.
rigau schrieb:
If the thread or hole in the wood is damaged, repair it with wood glue and, if necessary, a small piece of wood.
Professional repair is recommended here: For worn screw holes, first remove the old material, then glue in an appropriate wooden dowel. Afterward, pre-drill a new hole and fasten the screw. This provides a much stronger hold than wood glue alone.
For correct screw tightening: If you don’t have a torque wrench, work carefully by feel until the connection is noticeably firm, without forcing resistance.
In summary: clean the screws, repair holes with wooden dowels if needed, apply medium-strength threadlocker, and tighten carefully with suitable tools. This ensures a stable connection without damage.
