ᐅ Malm nightstand wobbles despite being attached to the wall – what tips can help?
Created on: 30 Apr 2023 19:07
renpirmin
renpirmin
30 Apr 2023 19:07
I have an Ikea Malm nightstand that is already mounted with the wall attachment. However, it still wobbles slightly with every touch – especially when I place something on it or move the cabinet. The wobbling is not strong but annoying, and I’m concerned that over time it could damage the mounting or the furniture itself.
I installed the wall bracket according to the instructions, and the screws are tight. The wall is a plastered concrete wall. Does anyone know this problem and have tips on how to reliably reduce or completely prevent the wobbling despite the wall mounting? What other fastening methods or techniques would you recommend? Is there maybe an easy retrofit solution that significantly improves stability?
I would really appreciate concrete and practical advice on how to make the Malm furniture truly secure and stable.
CARLA
30 Apr 2023 20:43
A solid and stable bedside table should, of course, not wobble, especially when mounted to the wall.
First of all, it is important that the fasteners used for both the wall and the furniture fit perfectly and are secure: For plastered concrete walls, always use anchors designed for concrete, such as expansion or sleeve anchors. Screws must be screwed deeply enough into the anchors.
Additionally, for Malm bedside tables, I recommend checking the original wall bracket. Often, the included screws and brackets are intended for standard walls but may not provide enough tension on thick plaster layers or uneven surfaces.
One way to reduce wobbling is to install a second fastener below the first one, for example, using special furniture brackets. These can further prevent tipping and wobbling.
If the bedside table rests on the floor, a small adjustable furniture foot can help compensate for wobbling and better distribute the load.
In summary:
- Check anchors and screws
- Install additional angle brackets or metal brackets
- Inspect furniture feet if there is floor contact
These are practical, simple measures that usually significantly improve stability.
floga
1 May 2023 10:38
CARLA schrieb:
One way to reduce wobbling is to add a second fastener below the first one
I can fully agree with that! I once had a similar case with a Malm chest of drawers that wobbled despite being secured to the wall. What really helped me was attaching an additional bracket at the bottom, which gave a lot of extra stability—you can immediately feel how the bedside table stands much firmer.
I completely understand how annoying wobbling can be. I also placed small rubber strips between the wall and the furniture to reduce direct friction. Maybe that could be an option if there are slight unevennesses in the plaster?
I’m also someone who likes to check for minor weak points in the furniture itself. Especially if the wall mounting is solid, it’s possible that the piece of furniture isn’t perfectly assembled or that the base plate rests a bit unsteadily. Just check to make sure all the screws inside the furniture are really tightened.
Overall, having patience and checking everything step by step helps. 🙂 Good luck!
Tevin
1 May 2023 13:22
I would like to briefly address the main points and also explain some basics in case they are helpful.
The wobbling usually occurs when either the wall fixings are not stable enough, the furniture is not resting flat on the floor, or there is some looseness inside the unit.
Regarding the original wall fixing, it is important to use:
- Suitable wall plugs and screws (depending on the wall type)
- Secure attachment to the furniture (usually a cross brace, which should be concealed)
If the bedside table is not level, it tends to slide, which causes the wobbling.
If the bedside table does not sit flat on the floor, you can try attaching small felt or plastic gliders under the feet to even it out.
renpirmin schrieb:
Trotzdem wackelt das Teil bei jeder Berührung etwas
This means that somewhere the load transfer is not properly secured.
My tip: Also check whether the wall fixing was attached properly for load bearing—not just at one point, but ideally at least two fixing points per piece of furniture.
One last tip: The Malm furniture system is relatively lightweight and not designed to bear high loads at small contact points. Additional floor fixing is unusual but can help if a more stable stand is desired.
I hope this sheds some light on the causes.
nojaus
2 May 2023 08:17
Tevin schrieb:
If the nightstand isn’t level, it tends to slide
I’ve noticed the same with my nightstand. Sometimes it’s barely visible, but if the legs aren’t sitting completely flat, small rocking movements can happen.
It might also help to take a closer look at the floor beneath the nightstand. An uneven floor surface, irregular carpet, or minor bumps under the furniture legs can increase wobbling.
Additionally, I’ve experienced with Malm nightstands that adjusting the alignment of the front doors can make a difference. If the doors aren’t hanging perfectly straight, the furniture can compensate for movement when bumped.
I think, besides securing the furniture to the wall, it’s important to check the piece itself and its placement. Trying small wedges or glides might reduce the wobble.
Wishing you patience – it’s usually a combination of several factors.
