ᐅ Laying Patio Slabs and Preventing Weed Growth
Created on: 20 Aug 2012 17:20
Mohnberger-1
20 Aug 2012 17:20
Hello everyone!
I want to build a patio using 40x60cm (16x24 inches) slabs of the type "Pallas grassano." This is my first time doing something like this, so I have a question: what is the ideal base for it? Gravel or crushed stone? What size or grain size should it be? How thick should the layer be?
I don’t want to have to constantly pull weeds out of the joints later on. What is the best way to prevent this? A friend said that even if I lay the slabs tightly together, plant growth could still develop in the cracks, and he recommended grouting the slabs with mortar. That seems a bit complicated to me... How would you approach this in my situation?
Irmi05-1
24 Jun 2014 11:44
We don’t have mortar between the slabs, so weeds and grass keep growing in the gaps. It’s not really a big issue, though; you just have to remove them occasionally. What stopped us from filling the joints was the fact that if a slab ever breaks, looks worn, or if you simply want a change, it’s easier to replace the slabs...
Louis-1
25 Jun 2014 07:40
If using mortar is too labor-intensive, just skip it. Then lay the slabs edge to edge and occasionally pull out any weeds.
Marcel-1
28 Jun 2014 11:01
That looks good when a bit of greenery shows through. I also don’t have any mortar between these stones. A little bit of weed isn’t a big deal.
Richard-1
8 Aug 2014 10:47
I would be bothered by the weeds, so I filled the joints with grout. The base layer is gravel, and proper compaction is important. The aggregate size is 32 mm (1.25 inches), and I applied it in a 10 cm (4 inch) layer. Everything is stable, looks good, and there are no weeds.
Robert-1
3 Oct 2014 17:01
The joints are not the problem, and if a slab breaks, it can easily be replaced. I have already relaid the entire terrace and removed the old slabs. That went very well. What bothers me is the weeds growing between the slabs.
