ᐅ Laying of electrical conduit pipes on the unfinished floor (screed with underfloor heating)
Created on: 28 Oct 2025 13:53
IPM_1985Hello everyone,
I am currently renovating my house (built in 1983) and installing a new underfloor heating system with screed.
The heating company has laid two pipes for two existing radiators (in rooms where underfloor heating is not possible, see picture below). I would like to do the same for cables in each floor (instead of routing them along the wall).
I believe there is a standard for pipe installation that requires a 20 cm (8 inches) distance from the wall. However, my screed installer said it would be better not to lay any pipes at all, but if pipes are installed, then as close to the edge as possible. This is quite confusing to me.
I want to discuss this topic here with experts to understand what is possible and what is not, based on the layout of the new screed.
Some information about the screed and installation height:
The total available installation height (from the raw floor to the top screed level where the tiles will be laid) is approximately 9.5 cm (3.7 inches).
Ground floor (GF)
1. PE film 0.2 mm (200 microns) as a moisture barrier, laid in a single overlapping layer on raw concrete slabs
2. PUR-aluminum insulation boards, 40 mm (1.6 inches) thick, made of polyurethane foam (thermal conductivity WLG 024), gas diffusion-tight on both sides with aluminum foil according to DIN 18 164 T1/B2
3. Grid film
4. Calcium sulfate flowing screed for underfloor heating, 50 mm (2 inches) nominal thickness, CA-C25-F5, pH ≥7 (EN 13813), installed as a floating screed over the heating system in accordance with DIN 18 560
Upper/middle floors (UF/MF)
1. Styropor- PS 20 SE insulation boards, 20 mm (0.8 inches) thick, thermal conductivity WLG 040, made of polystyrene according to DIN 18 164 T1/B1, delivered and installed in staggered joints
2. System panel 25/20 mm for underfloor heating, made of polystyrene (PS-TK/SE), thickness 25/20 mm (1/0.8 inches), impact sound and thermal insulation boards (WLG 045), stiffness group: 20 MN/m³; according to DIN 16 164 T. 2, fire protection class B1, factory-laminated with grid covering foil, for live loads up to 3.5 kN/m², delivered and installed including necessary edge strips
3. Calcium sulfate flowing screed for underfloor heating, 50 mm (2 inches) nominal thickness, CA-C25-F5, pH ≥7 (EN 13813), installed as a floating screed over the heating system in accordance with DIN 18 560
In my case, it does not exactly meet the standard because the pipes are not below the insulation boards.
Instead,
[IMG width="390px"]https://www.sanier.de/wp-content/uploads/images/estrich-rohrleitungen-ausgleichsschicht-grafik-Nebenkosten.jpg[/IMG]
it would look like this...
My questions:
1. Can I lay the pipes as planned directly on the raw floor? Would you recommend this, or do you see any risks (thermal bridges, etc.)?
2. Do I have to maintain a 20 cm (8 inches) distance from the wall, or can I place them exactly along the edges?
3. How does the insulation board fit with this pipe? Since the pipe and insulation board are at the same level, the pipe cuts through the insulation board. The underfloor heating pipes would be installed above anyway, correct?
4. What is the maximum allowable pipe diameter? I assume it should not exceed the thickness of the insulation boards—so 40 mm (1.6 inches) for the ground floor and 20 mm (0.8 inches) for upper/middle floors?
Thank you very much.
Ground floor (GF)
3. Grid film
Instead,
My questions:
Knöpfchen schrieb:
Nym cables as well as underground cables can/may be installed directly along the bottom of the wall without protective conduit.Thanks for the suggestion, but I definitely want to have conduits installed in case I need to change or replace the cables in the future.N
nordanney29 Oct 2025 08:22IPM_1985 schrieb:
Thanks for the suggestion, but I definitely want to have conduits installed in case I want to change or replace the cables in the future.Sorry, but it's a misconception that you will actually replace the cables. In my 30 years in the real estate industry (and in every case I know), I have never seen it happen. However, there are no arguments against an "I want to." ;-)
nordanney schrieb:
Sorry, but it’s a misconception that you can just replace cables. In my 30 years in real estate (and everyone I know), I’ve never seen that happen.
However, there’s no argument against an “I want to” ;-) My main concern is flexibility if I want to install new cables later, etc. I’m originally from Italy, where this is standard, and in 2005 I renovated my parents’ apartment from the 1970s (the original electrical system had massive conductors XD... if the cables had been installed directly in the walls, it would have been quite a mess). Maybe I’m somewhat biased. The house I bought (built in 1983) originally has cables installed in the walls, but for some reason they were already routed through pipes in the floor.
nordanney29 Oct 2025 12:35IPM_1985 schrieb:
Maybe I’m a bit biased here.Yep, that’s how it is.I can’t think of any reason to replace an electrical cable. In 50 years, electricity will flow the same way as it does now.
You could just swap an old cable for a new one (though the lifespan is actually around 100 years). However, that doesn’t avoid changes to the installation—light switches in different places, lamps moved around, etc.
Many cables can’t even be replaced because their bending radii don’t allow them to go around all the corners.
For that reason, I would only lay NYM cable on the floor.
