ᐅ Laminate vs. Hardwood Flooring
Created on: 29 Nov 2012 17:31
I had planned to install laminate flooring throughout the house, as I had good experiences with this type of flooring in my rental apartment. However, I’m now having doubts. Would hardwood flooring be better in high-traffic areas like the hallway and children’s rooms because it is more durable? How long does laminate flooring typically last when children walk over it with dirty shoes? Is it worth investing in high-quality laminate? Some laminate products are almost as expensive as second-grade hardwood.
Ultimately, I want a durable floor— is hardwood significantly better in this regard?
henry-1
19 Feb 2014 12:47
Parquet flooring is a fine and more durable option, but laminate has the advantage of being more affordable and does not need to be sanded and resealed every 4 to 5 years. Of course, parquet can also be sanded again later, but then the shrinkage cracks in the joints become even more visible.
Luca-1
5 Apr 2014 08:49
That’s clear, hardwood flooring is definitely a quality option. It is more expensive compared to laminate, but also more durable. However, I wouldn’t let children with dirty shoes walk on laminate, and certainly not on hardwood flooring.
Jonas-1
1 Jun 2014 09:01
The choice between hardwood flooring and laminate depends on several factors. Hardwood flooring is significantly more expensive than laminate. Although hardwood lasts longer, it requires regular sanding. For allergy sufferers, the dust can be problematic.
Serena1990-1
4 Jun 2014 00:28
But parquet is still better than laminate. It looks better and also lasts longer. Sanding and sealing only need to be done every few years.
Annegret-1
5 Nov 2015 12:38
Serena1990 schrieb:
But still, hardwood flooring is better than laminate. It looks better and also lasts longer. Sanding and sealing only need to be done every few years.
We have now also decided on hardwood flooring. It not only looks better but also lasts longer. We can manage the sealing as well.
