ᐅ Knee wall determined by floor plan and bay window configuration.
Created on: 6 Dec 2014 04:07
X
XinetteOnce again, we would like to hear your opinion. Due to the size of the floor plan and the existing bay window, we can build a knee wall of up to 87 cm (34 inches) at most. To have a higher knee wall, we would need to enlarge the house. What knee wall height do you have? Is 87 cm (34 inches) sufficient? We are tall people, 176 cm (5 ft 9 in) and 198 cm (6 ft 6 in), and the children probably won’t stay small either.
Your opinion is appreciated.
Thanks, Xinette
Thanks, Xinette
It depends on where the 87cm (34 inches) is measured. Is it on the outside or inside, relative to the finished floor level? We have an exterior knee wall of 150cm (59 inches) plus a 36cm (14 inches) wall thickness, which results in an interior knee wall of 165cm (65 inches) with a 42-degree roof pitch.
In general, I would prefer a minimum knee wall height of at least 100cm (39 inches) on the inside. Even better is 120cm (47 inches), so that you can actually place something there.
If you have a low knee wall, a steeper roof pitch (42 degrees or more) is recommended.
Inside, we have a knee wall height of 189cm (74 inches) with a roof pitch of 20°, and I find it great (I am 1.92m (6 ft 3 in) tall). A height of 150cm (59 inches) at 30° is also still comfortable, but significantly less is naturally associated with more compromises. In the end, it’s a matter of personal preference and how the space is furnished.
