ᐅ Is the KALLAX Shelf Suitable for Long-Term Use in Damp Areas?
Created on: 6 Oct 2024 08:12
burkard59B
burkard596 Oct 2024 08:12Hello everyone,
I am currently looking into whether the KALLAX shelf from IKEA can be used permanently in damp rooms. Specifically, I mean spaces where increased humidity or light moisture occasionally occurs, such as laundry rooms, garages with minor condensation, or semi-open bathroom areas.
The shelf is mainly made of wood-based panels, which are melamine-coated, but I still don’t think the material is designed for permanent exposure to moisture. I’m interested in whether there are any experiences or tips on how to make KALLAX more moisture-resistant or if it’s better to use completely different furniture.
So, is the KALLAX shelf, as sold, suitable for these types of environments? If not, are there practical modifications or alternatives?
I look forward to your informed opinions!
PeoDaniel6 Oct 2024 09:37Hello burkard59,
Good and important question! The KALLAX shelving unit is actually not designed for damp environments. The melamine-coated engineered wood panels are quite resistant to moisture, but prolonged exposure to water can cause the edges to swell.
A key factor is the type of moisture exposure: humidity in the air (for example, in a well-ventilated laundry room) is less problematic than direct splashing or standing water. Good ventilation also helps significantly to minimize damage.
There are ways to make the KALLAX unit more durable: for example, sealing the edges with waterproof varnish or placing the shelves on feet to avoid direct contact with the floor. Water-resistant films in high-exposure areas can also be helpful.
If you want to use the shelving in very damp areas, fully waterproof alternatives made of plastic or metal are often a better choice.
In general, I would say the KALLAX works if you keep moisture levels controlled and take preventive measures.
PeoDaniel schrieb:
A key point is the type of moisture exposure: humidity (for example, in a well-ventilated laundry room) is less problematic than direct splash or standing moisture.I can only agree with that. It is also important that the surface coating repels moisture but is not waterproof. With continuous wetness, water penetrates the panels and damages their structure.
If you want to use the KALLAX shelf long-term, pay attention to:
- Avoiding standing moisture
- Applying protective measures on the edges (for example, silicone seals or edge profiles)
- Regular inspections to prevent mold growth
If you have a project with high moisture levels, I recommend switching to furniture made of plastic or metal, which are specifically designed for damp environments.
The KALLAX shelving unit is not designed for permanent exposure to moisture. It is acceptable for short-term use in basements or laundry rooms, but it should not be exposed to direct moisture or standing water. Painting or sealing can provide some protection, but it does not replace furniture specifically made for damp rooms.
burkard597 Oct 2024 07:54blapau schrieb:
It is also important that the surface coating repels moisture but is not waterproof.Thank you for the important note! Now my question is: Are there practical tips for sealing methods that can be done at home with little effort? For example, which type of paint or materials are recommended to best protect the edges and surfaces?
Or is it necessary to invest in professional treatment to ensure the shelf lasts a long time? I would also like to know if such sealants significantly change the appearance – the shelf should remain as close as possible to its original look.
PeoDaniel7 Oct 2024 10:16burkard59 schrieb:
Are there any practical sealing tips that can be done easily at home without much effort?Sure, that’s definitely doable. You can use a transparent, waterproof polyurethane clear coat. It’s easy to apply with a brush, dries relatively quickly, and provides good protection against moisture. Make sure to treat the edges thoroughly, as they are the most vulnerable.
Alternatively, an epoxy resin coating can be very effective, but it’s more complex to apply and requires more experience.
Regarding appearance: The clear coat usually changes the look very little or makes the wood slightly glossier. In any case, you should test on sample areas before treating the entire shelf.
In summary: A coat of polyurethane clear finish is a good compromise between effort and protection—without significantly altering the shelf’s appearance.
