ᐅ Kallax connector loosened after moving – is there a replacement available?
Created on: 12 Sep 2024 08:37
islam60Hello everyone,
I recently moved my IKEA Kallax unit, and I noticed that the connector joints between the individual Kallax modules have become quite loose. Specifically, the connections no longer fit tightly and sometimes even wobble a bit. This is obviously an issue because it affects the stability of the shelves. Now I’m wondering if anyone knows of a way to replace or repair these worn connector joints.
I have been thinking about whether original replacement parts are available or if there are alternative repair methods, such as using special dowels, adhesives, or other fastening systems that can be retrofitted.
Has anyone here dealt with Kallax connector joints after moving or have tips on how to secure them again without having to buy a whole new unit? I’d appreciate concrete suggestions, preferably with sources if possible.
Thanks in advance!
Thanks in advance!
Hello islam60,
First of all, your issue with the worn-out connectors on Kallax units after moving is understandable. The plug-in system is convenient, but repeated assembly and disassembly can weaken the material’s stability.
Regarding your questions: As far as I know, IKEA does not offer individual replacement connectors for Kallax. Usually, only the entire carcass can be replaced. However, there are some alternatives:
1. You can try filling the connector holes with wooden dowels or wood chips combined with glue to reinforce the joint.
2. There are so-called replacement pegs for furniture connector systems available at hardware stores or online. You can use these to replace old, damaged fasteners.
3. Some users additionally strengthen the connection by attaching small angled metal brackets (corner braces) inside the corners, which increases stability.
If you decide to use glue, I recommend a high-quality wood adhesive with strong bonding. Keep in mind, though, that this will make disassembly impossible afterward.
If you need more details about these repair methods, just let me know. 🙂
benon schrieb:
To my knowledge, IKEA does not offer individual replacement connectors for Kallax.That is correct. IKEA generally does not sell single connector pieces for Kallax but only complete modules.
Regarding the technical aspect:
Kallax primarily uses particleboard or MDF elements in its connection system, with plastic or wooden connectors inserted into pre-drilled holes. Frequent disassembly can cause the material around the hole to fray, which explains the loosening.
Repair recommendations:
- Use wooden dowel repairs to fill the enlarged hole and secure the fit of new connecting pins.
- Apply epoxy resin for a durable and stable coating of the damaged joint.
- Alternatively, replace the entire panel if a stable connection cannot be ensured.
When gluing in dowels, pressing for several hours is recommended.
Important: The replacement connector should provide the same mechanical strength, so reinforcing with metal brackets is often highly advisable.
PeoDaniel13 Sep 2024 13:57Hello islam60,
I had a similar problem after my move. Unfortunately, the plug connections were no longer very tight. My solution was a combination of:
- Inserting wooden dowels with wood glue into the old holes (otherwise the plug system is too loose).
- Then reinforcing the connections with small metal brackets on the inside. Choose the correct screw length to avoid splitting the wood.
This significantly improved the stability. The wood glue provides a permanent bond, the dowels fill the worn holes, and the brackets offer extra support.
If you need the assembly to remain removable, I would completely avoid dowels and stabilize only with metal brackets. However, this means it’s no longer entirely “pure” to the original system.
I can only recommend this method, and it has worked very well for me.
islam60 schrieb:
This specifically means that the joints no longer fit tightly and may even be a bit loose.Regarding the current situation: The loosened joints in Kallax mainly result from the wood fibers around the drill holes softening after repeated assembly and disassembly.
PeoDaniel schrieb:
Insert wooden dowels with wood glue into the old holes[...] then reinforce the joints with small furniture brackets on the inside surfaces.This method is effective and is also used in furniture manufacturing for repairs.
Additionally, I recommend choosing dowels made from high-quality wood (beech or oak), as these are easier to work with and more durable.
If the shelves are not load-bearing and appearance is more important, replacing individual panel elements can also be considered, although this is usually labor-intensive.
