ᐅ Is this sink compatible with this faucet/tap?
Created on: 13 Sep 2016 09:47
schoenerwohn
schoenerwohn
13 Sep 2016 09:47
Good morning,
I would appreciate some professional advice. I have a sink and a faucet, but I am unsure whether they are compatible.
The sink is without an overflow. According to the plumbing company, a faucet without a pop-up drain assembly must be used in this case.
My desired faucet (a Swedish subsidiary of Villeroy & Boch, called Gustavsberg) looks like this:
[ATTACH alt="dieses-waschbecken-kompatibel-mit-dieser-armatur-154261-2.png"]12094[/ATTACH]
Does this combination fit together in terms of overflow/drain assembly?
Thank you very much in advance for any advice.
Neige13 Sep 2016 11:00
The actual faucet is not related to the drain. This simply means that faucets can be ordered with or without a drain, as well as with or without an overflow connection.
AOLNCM13 Sep 2016 11:20
For a sink without an overflow, you should use a basin mixer without a rod-operated drain assembly and a drain valve without overflow function (no push button or pop-up drain).
Neige13 Sep 2016 11:28
....UPS.... in my post, it should have continued with ordering. But @AOLNCM has already written.
schoenerwohn
13 Sep 2016 11:31
Thank you for the information. As I understand it now, the above faucet is basically usable.
@Neige, what is the overflow connection? Does the above faucet have it?
(sorry, this is the first time I’m ordering a faucet)
Neige13 Sep 2016 11:48
An overflow connection is part of the drain fitting that helps the water in the basin—if water is accidentally left running—to drain away. Since you have a basin without an overflow, it was mentioned:
AOLNCM schrieb:
you should use
a basin faucet without a lift rod drain assembly
meaning one with a lever on the side, behind, or similar, and not one that includes a lift mechanism as part of the faucet, and
AOLNCM schrieb:
use a drain valve without overflow function (no push button or pop-up type).
This way, the water can continuously drain. In other words, the drain valve in the basin either cannot or should not be closed.
