schoenerwohn13 Sep 2016 09:47Good morning,
I would appreciate some professional advice. I have a sink and a faucet, but I am unsure whether they are compatible.
The sink is without an overflow. According to the plumbing company, a faucet without a pop-up drain assembly must be used in this case.
My desired faucet (a Swedish subsidiary of Villeroy & Boch, called Gustavsberg) looks like this:
[ATTACH alt="dieses-waschbecken-kompatibel-mit-dieser-armatur-154261-2.png"]12094[/ATTACH]
Does this combination fit together in terms of overflow/drain assembly?
Thank you very much in advance for any advice.
schoenerwohn13 Sep 2016 11:31Thank you for the information. As I understand it now, the above faucet is basically usable.
@Neige, what is the overflow connection? Does the above faucet have it?
(sorry, this is the first time I’m ordering a faucet)
An overflow connection is part of the drain fitting that helps the water in the basin—if water is accidentally left running—to drain away. Since you have a basin without an overflow, it was mentioned:
meaning one with a lever on the side, behind, or similar, and not one that includes a lift mechanism as part of the faucet, and
This way, the water can continuously drain. In other words, the drain valve in the basin either cannot or should not be closed.
AOLNCM schrieb:
you should use
a basin faucet without a lift rod drain assembly
AOLNCM schrieb:
use a drain valve without overflow function (no push button or pop-up type).
