ᐅ Is the plaster still too wet, or has it already dried to the normal level?
Created on: 20 Jan 2018 17:22
3
305er
Hi, the interior plastering of our new build made from Ytong was completed on 10.10.17.
On 23.10., the cement screed was installed with an added fast-drying agent. According to the screed installer, it can be covered after 14 days.
Now it is the end of January, and in some rooms on the upper floor, certain spots are still damp.
After Christmas, we used a construction dryer for 10 days, which extracted about 1-1.5 liters per hour.
We have been ventilating regularly.
The floor heating drying program never ran properly before, but it is finally working continuously now.
It was assumed the walls were dry, but when the underfloor heating was heated again to 35°C (95°F), the same areas were damp the next day.
One spot/corner sounds hollow when tapped near the dry area.
Is this still normal for these spots due to the extreme heat, or do we have a moisture problem?
Our completely useless site manager says it is normal.
The worst areas were before the construction dryer was used.
Innenwand-Ecke mit Feuchtigkeit, Flecken und Verfärbungen an Wand und Decke
Ecke einer weißen Wand und Decke mit Riss und Putzabplatzungen.
Feuchte Wand in einer Innenraumecke mit Schimmel- und Fleckenbildung.
Unverputzter Innenraum in einer Ecke mit sichtbaren Verputzarbeiten, rauem Boden und Steckdosenleiste
Feuchtigkeitsspuren in Innenraum-Ecke an Wand und Decke, Renovierungszustand.
11ant21 Jan 2018 01:24
305er schrieb:
They usually work for a prefabricated house company (timber frame)... but don’t they also use plaster, right?
They probably use drywall instead.
Sometimes I think you’re a bit of a defectphobic, almost like a kind of hypochondriac among builders.
305er21 Jan 2018 09:22
I am neither mentally ill nor do I constantly believe that I have a serious illness.
And sorry, after so much nonsense that has already been done, I prefer to ask twice. Besides, this is a reasonable question: why does it always get damp in those corners?
305er21 Jan 2018 11:57
Very recent....Humidity at 81%
Alex85
21 Jan 2018 12:08
So you believe that areas which are already dry will become wet again? That is how I understand it?
305er21 Jan 2018 13:00
No, we thought they were dry.
V
VelBau
21 Jan 2018 18:05
It’s the same for us; in some corners, you can still see damp spots! (Interior plastering on 20.10., screed on 24.11.).
I read that about 2,800 liters of water are introduced per 100 sqm (1,076 sq ft) of new construction area. We heat and ventilate 3-4 times a day. A small construction dehumidifier is also in use, removing about 5-10 liters (5-10 quarts) per 24 hours.
