ᐅ Is it possible to use BILLY shelves securely without a back panel?
Created on: 1 Nov 2019 18:32
jorunn
I am currently considering whether IKEA BILLY shelves can be used stably without the back panel.
I understand that the back panel generally contributes to the stability of BILLY shelves, as it secures the shelf laterally and prevents twisting. However, I would like to make the shelf look visually more open, for example, open from the back without the back panel, and I am wondering if there are ways to ensure stability nevertheless – for example, through alternative fastenings, anchoring to the wall, or other additions.
Does anyone have experience or knowledge about how practical and safe it is to use the shelf without the back panel? Are there any particular tips I should consider to maintain stability? I look forward to your assessments and advice.
Deandre
2 Nov 2019 14:05
Hello jorunn,
to thoroughly answer your question "Is it possible to use BILLY shelves without the back panel in a stable way?" I would like to explain in more detail:
BILLY shelves are designed by default to rely on the back panel for stability. This back panel takes on loads and prevents the shelf from twisting or tipping sideways. Without this back panel, this important element is missing.
However, if you attach the shelf to the wall, for example using the black corner screws from IKEA, the stability is significantly increased. This creates a mechanical connection to the wall that partially compensates for the missing back panel.
Additionally, you can take the following measures:
- Attach metal corner brackets inside at the sides and at the bottom/top
- Distribute loads evenly and place heavy items at the bottom
- If in doubt, replace the back panel with a thinner but sturdy board, such as MDF or plywood, to maintain an open look
So it is possible to use the shelf without the back panel in a stable way, but only with additional reinforcements and careful loading.
I hope this helps you!
ritotar
3 Nov 2019 10:22
Hey jorunn and all other shelf fans 🙂
I tried it without a back panel – and I have to say, I was skeptical at first. But with two angled brackets on the wall, it holds very securely and looks really stylish because it appears much lighter visually.
That’s really great advice, it’s the only way to improve stability.
So if you’re a bit adventurous, you can definitely go for the open look. 🙂
theo63
4 Nov 2019 08:19
ritotar schrieb:
I tried it without a back panel – and I have to say, I was skeptical at first. But with two angle brackets attached to the wall, it holds very securely.
I’m glad to hear that, but do you think this approach should remain experimental in the long term? From a technical perspective, angle brackets are at best a compensatory measure. The real weak point remains: the lack of diagonal bracing.
Are there any experiences on how the shelf performs over several months? Especially when it is moved or leaned on more forcefully?
Knowing this would be important to better assess the risk.
jorunn
5 Nov 2019 13:51
theo63 schrieb:
Are there any long-term experiences on how the shelf behaves over several months? Especially if it is moved or leaned on more firmly?
Thank you all for the detailed responses so far.
To answer your question: About a month ago, I assembled a BILLY shelf without a back panel and secured it to the wall with two angle brackets. So far, it has held up very well, even when I occasionally touch it lightly or place items on it. I do notice it is somewhat more flexible than with a back panel, but tipping is practically ruled out.
However, I made sure not to put excessive weight on it and placed books and decorations mostly on lower shelves.
I think it really depends on the type of wall mounting and how the load is distributed. I accept the slightly reduced stability because of the open design.
If anyone else has long-term experience, I would appreciate hearing about it!
