ᐅ Is it possible to install drywall over insulated wood fiber wallpaper?
Created on: 17 Apr 2021 16:13
HausBaujahr62
HausBaujahr62
17 Apr 2021 16:13
we have purchased a house built in 1962 with an extension from 1992. In the extension, the exterior walls are lined on the inside with an insulated wallpaper. It seems to be a manufactured product: a textured wallpaper with a 1cm (0.4 inch) soft, white insulation layer. We want a smooth interior wall. Removing the insulated wallpaper is difficult and leaves adhesive residues (which were applied back then with a fine toothed spatula). Do we risk mold if we simply screw or glue drywall panels over the wallpaper?
Thanks for any advice!
Good luck
i_b_n_a_n17 Apr 2021 18:03
You will curse, cry, and groan, but do yourself a favor and do it right the first time. A "layered construction method" will always come back to haunt you—unless you give up even more space and build a proper, full drywall partition in front of it (which you can then also use as a service cavity for new electrical installations). I have experience with shoddy work in old houses and, looking back years later, I curse every penny saved and every minute cut short.
11ant17 Apr 2021 18:49
Even smoother than wallpaper? Are you looking for paint or tiles?
HausBaujahr62
17 Apr 2021 19:33
It currently has textured wallpaper, and we would prefer it smooth, that is, plastered and painted. I think you are right, and I will remove it.
HausBaujahr62
17 Apr 2021 19:34
Thanks for the answers! Great forum here 🙂
