ᐅ How can I securely mount Billy shelves on drywall (gypsum board) walls?
Created on: 13 Jun 2021 08:37
Bidi35
Hello everyone, I am planning to mount several Ikea Billy shelves on a drywall partition and want to do this as securely and permanently as possible. The wall is made of gypsum plasterboard with a metal stud framework – no wooden studs. My question is: What type of anchors or fasteners are best suited for hanging heavy shelves like the Billy, so that the load is well distributed and nothing pulls out? Are there any special installation methods I should follow to ensure the shelves not only hold but remain stable in the long term? I would appreciate any advice on the procedure, suitable screws, and anchors, especially considering the specific characteristics of drywall. Thanks!
tolokau
14 Jun 2021 09:21
Bidi35 schrieb:
Is there a recommendation for the ideal screw length?
The ideal screws are about 25–30 mm (1–1.2 inches) longer than the thickness of the drywall panel, so they securely anchor into the metal stud. Standard drywall panels are 12.5 mm (0.5 inches) thick, so using metal screws that are 40–50 mm (1.6–2 inches) long should work well.
Bidi35 schrieb:
Do I need to be careful when drilling or screwing to avoid damaging the drywall panel?
When pre-drilling, apply light pressure to avoid cracking the drywall. When screwing, target the metal stud precisely so the screw fastens into the metal, which will hold the shelf firmly. Screwing directly into the drywall applies pressure that can cause damage, so always screw into the stud.
Summary:
- Locate the metal stud
- Pre-drill with a metal drill bit
- Use 40–50 mm (1.6–2 inches) metal screws
- Apply screw pressure into the stud, not just the drywall
maugi
14 Jun 2021 10:43
Hi, this whole thing is really exciting – with drywall (plasterboard) you often have some doubts, but with the right method it holds very well! 🙂
I always hung my Billy shelves using hollow wall anchors, distributing the anchors evenly. It’s really important to distribute the weight properly.
If you don’t have a metal detector, you can also tap lightly to locate the metal studs – it might sound old-fashioned, but it works well.
And one more tip: if you’re hanging shelves with a lot of books, it’s better to use additional bracket supports that you fix with screws to both the shelf and the wall – this prevents any tilting stress. 😊
