ᐅ How can I stabilize Ikea HEMNES shelves on an uneven floor?
Created on: 15 Apr 2022 08:17
pakau
I recently purchased several Ikea Hemnes shelves and noticed that my floor is quite uneven. Because of the unevenness, the shelves don’t wobble immediately, but they are not stable and feel shaky. I want to solve this issue permanently without affecting the appearance or reducing the shelves’ stabilizing function.
My question is: What are the best ways to stabilize Ikea Hemnes shelves on uneven floors so they stand securely and do not tip or wobble? I have thought about leveling feet, shims, or pads, but I am unsure which option is best and how to apply it properly. What experiences do you have with this? Thanks in advance!
pakau
15 Apr 2022 11:00
zarJody68 schrieb:
The original feet of the HEMNES models are usually screwed in and can be replaced with leveling feet.
Thank you for this information; until now, I had assumed the feet were fixed in place.
SUBEN60 schrieb:
Permanent stability is achieved through careful adjustment and always by fixing to the wall.
The point about wall fixing is important. In my case, however, the problem is that the shelves stand vertically but still feel wobbly due to uneven floors. While wall fixing prevents side-to-side tipping, it does not stabilize the base.
Are there any experiences on how to position wedges so precisely that long-term stability is ensured? Is regular self-adhesive rubber sufficient, or should particular materials or designs be preferred?
tra_nina
15 Apr 2022 11:29
A permanent height adjustment using wedges works reliably if the following points are observed:
- The wedges must be durable and non-slip; materials like cork or rubberized wood are ideal.
- Choose size and shape so that they fit securely under the base feet without slipping.
- If necessary, fix them in place with double-sided tape.
- Clean the contact surface before placing the wedges to remove dust or oil.
This effectively prevents slipping and later instability. I have personally used such wedges in several cases, and they hold firmly over time on both wooden floors and tiles.
sanjon
15 Apr 2022 11:51
I used rubber wedges that can be adjusted in height. They are quite affordable and easy to customize. Important: Level each support foot individually and then test again under load. Always secure shelves to the wall.
pakau
15 Apr 2022 14:17
tra_nina schrieb:
A permanent height adjustment with shims works reliably if the following points are observed:
Thank you, that is very helpful. The tip about double-sided tape is especially interesting since I noticed that the shims can shift even with slight contact.
Question: What about the visual compatibility? Hemnes shelves are often in living areas, so are there wedge or support solutions that look more discreet and don’t interfere with the design? Or how do you handle this?
gadalu
16 Apr 2022 08:02
As a visually discreet solution, I recommend transparent rubber pads or felt-coated furniture glides. These can usually be glued under the legs and are hardly visible, especially on darker floors.
Alternatively, there are leveling feet with removable covers that remain flush and look neat. This ensures both stability and aesthetics.
It is important to measure the unevenness accurately before installation.
pakau
16 Apr 2022 10:33
gadalu schrieb:
It is important to precisely measure any unevenness before installation.
Thanks, I will definitely approach this carefully.
Here is a summary of my next steps:
- Check the floors at the installation locations using a spirit level and possibly a tape measure
- Choose suitable shims (preferably cork or rubber) that are visually matching
- Secure the shims with double-sided tape and, if needed, additional adhesive coating
- Upgrade shelves with adjustable furniture feet where possible
- Install additional wall fixings
Would you consider this a sensible and practical plan?
