ᐅ How do I safely assemble Ikea Metod cabinets with metal handles?
Created on: 12 Feb 2017 08:43
dimitriosD
dimitrios12 Feb 2017 08:43Hello everyone,
I am planning to assemble several Ikea Metod kitchen cabinets with metal handles and want to focus especially on a secure and stable installation. Specifically, I am interested in which steps or techniques you recommend to build the cabinets in a way that ensures long-term stability, particularly considering the metal handles, which are expected to withstand a bit more stress.
Which screws, anchors, and fastening methods have proven reliable? Are there any tips for preparing the materials and aligning the cabinets? And how can you effectively prevent the metal handles from loosening during use or damage to the cabinet body?
I look forward to concrete, experience-based advice, including recommendations on tools or special steps often overlooked. Thank you very much in advance for your support!
Hello dimitrios,
Since the Metod cabinets have a modular and relatively sturdy design, I recommend first leveling the cabinets precisely with a spirit level before starting the assembly. This will prevent later stresses.
- Use the original Ikea screws to ensure proper fit.
- Always select appropriate wall anchors based on the wall type (e.g., heavy-duty anchors for concrete) to secure the cabinets to the wall.
- I tighten metal handles with a hex key (Allen wrench), which allows controlled torque application to avoid damaging the material.
- I recommend attaching the handles only after the cabinet carcass is fully assembled to prevent damage from movement during assembly.
Additionally, it is worthwhile to check the cabinet corners for any twisting before completing the assembly and, if necessary, reinforce the joints with wood glue. This increases stability. A cordless drill with adjustable torque is advisable to prevent over-tightening the screws.
TEKIN schrieb:
Metod cabinets have a modular and fairly sturdy designThat is absolutely correct. I would add that you should ensure a clean workspace during assembly to avoid scratches. It also helps to sort the individual components beforehand and to follow the instructions carefully, step by step.
For safety when attaching the metal handles: if you notice that the screws don’t tighten properly, it might be due to incorrect screw lengths. In this case, use shorter screws to prevent gaps or cracks in the material.
The hinge installation should also be done gently – overtightening can enlarge the drilled holes. If you plan to store very heavy items, I recommend adding extra back panels or reinforcements to increase stability.
If you are assembling the unit alone, a step ladder or platform is also advisable, as it makes working at height easier and reduces the risk of accidents.
barEsperan13 Feb 2017 14:37Have you regularly tightened the screws on the handles? This is important because metal handles can loosen due to vibrations.
Also: screw them in straight, not at an angle, to ensure the handle stays secure.
Don’t forget wall mounting – a sturdy attachment keeps the entire cabinet safely in place.
Annedeo schrieb:
If you notice that the screws don’t tighten properly, it could be due to incorrect screw lengths.This observation is very important. Additionally, I would like to add that with Metod cabinet doors, the metal handles should always be tightened carefully and evenly—the uneven pressure can cause misalignment and gaps.
When hanging the cabinets, be sure to use the supplied brackets and secure them to the wall with appropriately sized screws and wall plugs (anchors).
A practical tip: using a drill with a depth stop helps prevent drilling too deep and damaging the back of the cabinets.
In summary:
- Screw carefully and straight
- Install metal handles only after the cabinet carcass is fully assembled
- Attach to the wall using suitable wall plugs (anchors)
- Regularly check the screws on the handles
- When in doubt, tighten gently; screws often hold more than you expect
