ᐅ How can I best customize Billy bookcases to fit into alcoves?
Created on: 22 Mar 2016 09:13
Gareo
Gareo
22 Mar 2016 09:13
I am planning to fit several Billy shelves from Ikea into niches in my apartment. The niches are somewhat irregularly shaped—not simply 60 cm (24 inches) deep or wide, but sometimes slightly narrower or wider. My goal is to adjust the shelves as best as possible so that they stand securely, look good, and make efficient use of the available space. What methods or tools would you recommend for precisely shortening or adjusting the depth of Billy shelves? Are there any special tips to make fitting shelves into corners and niches easier and cleaner?
Looking forward to your tips and experiences!
Tause
22 Mar 2016 11:48
Gareo schrieb:
The recesses are somewhat irregularly shaped, not simply 60cm (24 inches) deep or wide, but sometimes narrower or wider.
This is exactly where the problem lies: Billy shelves are standardized. To fit them into irregular recesses, I would first take very precise measurements in millimeters. After that, using a circular saw with a guide rail is recommended for accurate cuts.
Gareo schrieb:
What methods or tools do you recommend for precisely shortening or adjusting the depth of Billy shelves?
A router is invaluable for rounding off edges when pieces need to be inset or modified. Also, you might consider replacing the standard particleboard backing with a thin plywood sheet or birch plywood since it is easier to cut. The stability is hardly affected.
I also believe it is necessary to secure the shelves with corner brackets and possibly additional fastening to the wall or recess if the exact fit cannot be achieved.
FELOTAU
23 Mar 2016 07:36
I understand that a DIY project like this can sometimes be quite challenging, especially when dealing with variations in niche dimensions. What helped me personally was first creating a template of the niche using cardboard or stiff paper. This allowed me to test on the Billy shelf where cuts or adjustments were needed without working directly on the real shelf.
This approach takes a lot of pressure off and helps prevent mistakes. I also believe that a calm approach and patience are very important to ensure everything fits satisfactorily in the end. If you’re unsure, you can also mask the areas to be cut with painter’s tape – this protects the surface from splintering during cutting. Good luck, you can do it! 🙂
mipau
23 Mar 2016 12:05
Cut the shelves to size using a jigsaw. Smooth the edges with sandpaper. Replace the back panel with a thin chipboard or plywood sheet. Attach brackets and screws for reinforcement. Done.
NUGRANT
24 Mar 2016 16:42
This is fantastic, how everyone is pitching in together! 🙂
I added side strips to my Billy shelves, which I screwed onto the niche walls. This way, I can position the shelves precisely, and with small gaps, they look almost like custom-made built-ins!
And if you ever cut too much, you can fix it with self-adhesive trim strips – they look great and give the edges a nice finish. So, keep at it, it’s going to turn out awesome! :-)
