I am currently planning to install Ikea Pax wardrobes in my older apartment. The rooms are quite old, with walls made of solid masonry (partly brick, partly calcium silicate blocks) and partially crumbling plaster. The walls are not always perfectly even. My question is: How can I securely and safely attach Ikea Pax wardrobes to this type of older masonry without damaging the structure or risking insecure anchoring?
I have read that special anchors or fixings are often necessary for older buildings, but I am not very familiar with the exact materials and requirements. Are there specific fastening methods that have proven effective for uneven and crumbling masonry?
I look forward to your advice, especially regarding suitable anchors, screws, or alternative mounting methods.
Thanks in advance!
Thanks in advance!
Dopoki schrieb:
A precise on-site material analysis is important, so you can choose the right anchors.That’s the key point. I would recommend not only considering the assumed substrate but having it professionally tested beforehand if it seems unreliable. Especially crumbling plaster and hidden cracks can lead to failure later on.
noge58 schrieb:
Great question, fastening can really be tricky with older buildings! 😊Just praising heavy-duty anchors without knowing their correct application or load calculation is not very helpful.
If a professional material test isn’t possible, I advise opting for a bracket or freestanding solution on uncertain walls instead of relying solely on anchors. When in doubt, a combination of masonry anchors and substructure is sensible.
Also: what about the moisture level of the walls? That also affects the durability of anchors and mounting systems.
Hi, this whole thing has its charm, especially in characterful older buildings! ?
When walls are uneven and the plaster is crumbling, I love the idea of using mounting panels – it almost feels like being a magician who brings order to chaos! ✨
Wood panels like plywood or OSB (depending on your preference) are strong, relatively lightweight, and great for screwing into. This way, you can securely place your wardrobe on a solid base, and the cabinet will thank you by standing firm.
Also: pushing your heavy friend directly into the wall would be bold without good anchors, so it’s better to bring an extra level of safety. You don’t want a wardrobe disaster, especially not after the holiday feasting! ?
So, planning, preparation, and then you’re ready to go. Good luck, and let us know how it went!
