ᐅ How can I set up Wi-Fi and telephone services, as well as technical installations, in the basement?
Created on: 17 Sep 2020 15:09
Baugreenhorn
Since I am a complete beginner in the IT field, I’m asking for your help.
We are currently building a semi-detached house. Because of the underfloor heating, I have planned a CAT7 connection on every floor.
Now I’m wondering how I can later provide Wi-Fi and telephony throughout the house.
The incoming service line is located in the basement.
How can I distribute the telephony and Wi-Fi in the house using a FritzBox? I was thinking of installing an access point at the CAT7 outlets on every floor where needed. But how do I get the LAN connection there? Is it enough to connect the FritzBox in the basement to the network ports that end at the CAT7 outlets and then set up access points?
Also, I need to know how to connect a telephone (which will be located on the ground floor) to the FritzBox that is in the basement. Maybe Wi-Fi telephony?
Sorry for my awkwardness and many thanks for your help!
Ötzi Ötztaler
20 Sep 2020 13:06
And it is precisely with multicast for MagentaTV that most professional routers fail. This is because the corresponding protocol is apparently not used very often in professional environments.
T_im_Norden
20 Sep 2020 13:07
You have it through the FRITZ!Box guest network.
K1300S20 Sep 2020 13:08
That probably depends greatly on what is considered professional. In any case, I don’t know of any device that truly deserves that label and supports IGMP properly.
Mikrotik, for example, handles it without any issues.
Tarnari20 Sep 2020 13:39
K1300S schrieb:
That probably depends a lot on what you consider professional. As far as I know, no device really deserves that label without properly supporting IGMP.
For example, Mikrotik handles this without any issues.
It’s mostly the larger switches that are not so easy to find. I had to search for a long time to find a 48-port, PoE-capable switch that supports IGMPv3. The popular Unifi switches are already out of the question for this. The Edges can do it. In the end, I went with Cisco.
K1300S20 Sep 2020 13:43
As is often the case: quality comes at a cost, and especially when building a single-family home, you don’t just spend four-figure amounts on a switch. I would only partially classify Ubiquiti devices as professional, but they tend to be reasonably priced.
Tarnari20 Sep 2020 13:46
I don’t think the investment of 800€ for such a switch in a single-family house is excessive. This way, you get everything “out of the box.”
