ᐅ How can I get rid of leftover carpet pieces?
Created on: 21 Nov 2008 07:29
Alfred-1
21 Nov 2008 07:29
I removed the carpet in one room, and underneath there was an old PVC floor that has to remain in place. Now, the floor is covered with carpet residue that can only be removed with a scraper. But if I have to scrape everything off, it will take weeks, and it’s also strongly adhered to the PVC. What can I do?
Klaus-1
21 Nov 2008 09:24
Hi,
you can rent a machine that removes this from the floor. However, if the old PVC underneath should not be damaged, this might not be feasible. You could try using a heat gun; it softens the residue, allowing you to carefully scrape it off the floor with a spatula. Good luck with that!
Rudo-1
23 Nov 2008 08:05
this is really a problem, because if you are not allowed to damage the PVC, then a putty knife won’t help either. Even if you work very carefully, you will still cause some scratches here and there. Maybe there are chemical agents that can remove it?
Z
Zement-1
25 Nov 2008 07:32
try using a hairdryer to warm the residue; when heated with a hairdryer, it comes off more easily. This does not damage the surface underneath, and you don’t have to scrape as much. But I can only wish you that it goes away completely because that is a really nasty problem.
schwarzmeier-1
8 Jan 2009 23:57
TEBO leftovers
The key question is: Is the TEBO glued, secured, or loosely laid? If it is only secured or loosely laid, the problem might possibly be solved with warm water and some dish soap. If it is glued, I would consider contacting my liability insurance or just praying. 😀 😱 🙁
Jonas-1
9 Aug 2014 11:23
I just experienced the same and warmed up these carpet remnants with a heat gun. Then I removed them using an electric scraper. At first, I was a bit cautious, but it went quite well and nothing got scratched.
