ᐅ Are PVC ventilation ducts safe regarding harmful substances such as plasticizers?
Created on: 22 Oct 2025 07:12
RealUnreal
RealUnreal
22 Oct 2025 07:12
Hi!
I need supply and exhaust ducts for a decentralized controlled residential ventilation system.
Condensate will also drain through the exhaust duct.
I also need (smooth inside) 15-degree elbows.
So far, I have only seen these made from PVC.
Apparently, PVC can be harmful to health because it may release pollutants, but this might only apply to flexible PVC (plasticizers) and not to rigid PVC.
Can anyone provide some information on this?
Thanks and best regards
RealUnreal
Rübe1
22 Oct 2025 08:40
The manufacturer of these devices surely also offers suitable piping materials (commonly: food-grade PP) in their portfolio. Or is this a very special custom system?
RealUnreal
22 Oct 2025 11:05
Rübe1 schrieb:
The manufacturer of these devices surely also offers suitable pipe material (commonly: food-grade PP) in their product range. Or is this a very special system?
Hi and thanks for your reply.
These are Meltem heat recovery(1) units, and suitable pipes for supply and exhaust air are included.
However, I need one or more 15-degree elbows because I can't run the duct straight out of the wall.
As far as I know, Meltem doesn’t offer those.
Do you know where I can get something like that?
Rübe1
22 Oct 2025 12:25
Hmm, this naturally raises the question of whether the device is actually suitable for these requirements (multiple angles: always significant losses). Has anyone knowledgeable given this some thought? I haven’t looked at the diameters yet, but there are also insulated ducting options or the classic spiral seam duct...
RealUnreal
22 Oct 2025 14:09
Rübe1 schrieb:
Hmm, that naturally raises the question for me whether the device is really suitable for these requirements (multiple angles always mean significant loss). Has anyone competent given this some thought? I haven’t checked the diameters yet, but there is also isop... or the good old spiral duct...
Hi,
There is one angle for the supply air and one angle for the exhaust air.
I spoke with the manufacturer and they had no objections, especially since I only need a 15-degree angle and the total length is not increased.
What do you mean by Isop?
The manufacturer advised against using spiral duct because the internal ridges could cause problems with condensate drainage...
RealUnreal
22 Oct 2025 14:45
What I found is this:
[IMG alt="Bend 15° smooth DN 100"]https://www.der-luftshop.de/images/product_images/info_images/37684_Product.jpg[/IMG]
I hope that "smooth" refers to the inside.
However, I rather doubt that it seals properly just by being pushed on (condensation)?
