ᐅ How do I clean Malm furniture to remove stubborn dirt?
Created on: 12 Jan 2019 09:17
Lemuan
Lemuan
12 Jan 2019 09:17
I am specifically looking for an effective and gentle method to clean stubborn dirt on products from the Malm furniture series by IKEA. The surface of these pieces is painted, smooth wood or particleboard with a rather sensitive coating that should not be damaged by harsh cleaning agents. I am particularly interested in methods that can remove stains such as dried drinks, grease marks, or light scratches without dulling or scratching the paint. Are there any special home remedies, cleaning products, or procedures that have proven effective for heavy soiling, possibly with step-by-step instructions? It would also be helpful to know what to watch out for to avoid damaging the furniture.
PRA64
12 Jan 2019 10:03
First of all: It’s great that you mentioned the sensitivity of the surface, as this is crucial for choosing the right cleaning method.
Here is a structured approach that has often proven effective:
1. Preliminary cleaning: Remove dust and loose particles with a soft, damp cloth. Avoid scrubbing at all costs.
2. Gentle solution for grease and liquids: Mix lukewarm water with a drop of mild dish soap. Use a microfiber cloth to gently wipe the stains.
3. Stubborn stains: Dab a little isopropyl alcohol (rubbing alcohol, not too much!) onto a cotton swab and test it on an inconspicuous area. If the finish does not become dull, you can carefully treat the spots locally.
4. Scratches and dull areas: Lightly polish these spots with a furniture polishing pad or a soft cotton cloth and some car wax or furniture polish (specifically for painted surfaces).
5. Final treatment: Wipe everything down with a clean, slightly damp cloth and then dry the surface thoroughly with a soft cloth.
Common mistakes:
- Never use abrasive sponges!
- Avoid harsh chemicals, as they can damage the finish.
- Always test on a hidden spot first.
This step-by-step method helps extend the durability of the Malm surface and prevents damage. :-)
If needed, I can also provide a list of suitable products.
Germanro
12 Jan 2019 10:47
This is really important. I usually just use a soft cotton cloth with lukewarm water and diluted dish soap. For oil or grease stains, it helps to hold the cloth on the spot a bit longer, without rubbing.
jelite
13 Jan 2019 08:22
I would like to add a brief guide here, as I have often treated Malm furniture with difficult stains myself:
- Introduction: Malm furniture is usually made of particleboard with a smooth melamine or lacquer surface, which is sensitive to abrasion and harsh chemicals.
- Step 1: For dried-on beverage residues (e.g., coffee, juice), it is recommended to moisten the area with a damp cloth and let it sit for a few minutes before gently wiping. This helps loosen the dirt more easily.
- Step 2: For grease stains, a diluted dishwashing detergent without methyl alcohol works well. Important: Do not wipe too wet to avoid water absorption into the panels.
- Step 3: For scratches, gentle furniture polishing creams are helpful, but please avoid silicone-based car polish, as it can leave films.
- Summary: Be patient with preliminary cleaning, proceed cautiously with stains, perform small tests on inconspicuous areas, and always dry the surface afterward.
Mistakes to avoid: Avoid using excessive water, aggressive cleaners, and vigorous scrubbing.
For particularly stubborn stains, you can also use eraser sticks designed for furniture surfaces; these are slightly abrasive but should be used only sparingly and spot-treated.
draleo
14 Jan 2019 11:56
I would like to agree with the statements made by PRA64 and jelite, as they reflect the current cleaning recommendations for sensitive melamine surfaces like those on Malm furniture.
Additionally, I want to emphasize that aggressive chemicals such as ammonia or solvents like acetone must be strictly avoided. These not only damage the coating but can also break down the binding of the particleboard.
For particularly stubborn dirt, I recommend using a porcelain stoneware eraser, which is mildly abrasive but, when used correctly—short, gentle motions on small areas—proves very effective and safe.
The most important precaution is to always use microfiber cloths or soft cotton cloths, never rub aggressively, and wipe down afterward with a clean, slightly damp cloth.
If anyone requests a specific list of products, I can gladly provide one; among others, I recommend cleaning agents that are pH-neutral.
Following these tips should help clean the furniture while preserving the finish.
