ᐅ How do I attach BILLY to drywall (gypsum board/plasterboard)?
Created on: 4 Nov 2021 08:17
Meo-di5
Meo-di5
4 Nov 2021 08:17
Hello everyone, I plan to mount a BILLY shelf from IKEA on a drywall (plasterboard) wall. Since drywall panels are generally not as strong as solid walls, I want to make sure the shelf is installed securely and can bear weight without damaging the wall or risking the shelf’s stability.
My question is: What mounting methods and types of anchors are best suited for attaching BILLY shelves to drywall?
I have heard about special cavity anchors and also about reinforcing with wooden battens, but I’m uncertain which solution is best in which situations.
Also: How can I best estimate whether the wall will support the load, especially when I later fill the shelf fully with books?
Thank you very much for your advice!
Trenton
4 Nov 2021 09:22
For BILLY on drywall, I recommend cavity anchors, preferably metal toggle bolts. First, check the thickness of the panel with a depth gauge. If it will be heavily loaded, the anchors should be screwed into the wall studs (metal or wooden battens).
Danabla
4 Nov 2021 11:35
That is definitely the right approach. When mounting on drywall, it is especially important to use the correct anchors that not only hold in the panel but also secure safely behind the wall. Toggle bolts distribute the load over a larger area.
Meo-di5 schrieb:
Which fastening methods and types of anchors are best suited?
In addition to toggle bolts, I can also recommend spring toggle anchors, which often provide even more holding power. It is important to check before installation whether there is a metal or wooden stud directly behind the drywall panel. If so, you should try to screw directly into it, as that supports significantly more weight.
To assess load capacity: the load rating of a single anchor can vary between 20 and 50 kg (44 and 110 lbs), depending on the type, and the capacity adds up with multiple anchors. For fully loaded BILLY shelves, you should use at least four strong anchors per shelf and distribute them as evenly as possible.
If you want to be absolutely safe, you can have a wooden batten installed behind the drywall (for example by a professional), which can then serve as a support for the shelf.
nanidra
5 Nov 2021 07:47
Danabla schrieb:
To assess load capacity: The load bearing of a single anchor can vary between 20 and 50 kg (44 and 110 lbs) depending on the type, and with multiple anchors, this load adds up.
Interesting figures, but I often find the topic of regulations and manufacturer specifications for hollow wall anchors questionable. Manufacturers do provide load ratings, but these usually refer to ideal laboratory conditions. In practice, the values are often significantly lower – especially with drywall panels that are sometimes only 12.5 mm (0.5 inches) thick and may contain moisture.
In my opinion, when it comes to heavy furniture, it’s better to oversize: instead of using four anchors, use two or three times stronger anchors or additionally rely on a slatted substructure.
I also doubt whether the belief that you absolutely must screw into the studs is always the best solution. With flexible fastening using appropriate anchors and multiple distribution points, you can also achieve good stability without hitting the studs – especially when the wall studs are metal and no suitable drill bit fits.
So the issue is more complex than it is often presented and requires an individual evaluation. Also: How exactly do you plan to load the shelf? Books and other loads vary significantly in weight.
Meo-di5
5 Nov 2021 10:03
Danabla schrieb:
It is important to check before installation whether there is a metal or wooden stud directly behind the drywall. If so, you should try to screw directly into it, as this can support significantly more weight.
Thanks, that’s a helpful tip! Today, I checked the wall using a stud finder or cable detector. It seems there really are metal studs, but they are spaced quite far apart.
nanidra schrieb:
I often find the topic of regulations and manufacturer specifications for cavity anchors quite questionable.
That makes sense, especially with older walls.
I plan to use the shelf for books, so it will carry a considerable amount of weight. Maybe it would be sensible to use larger toggle bolts where there is no stud and also secure the back panel of the shelf to the wall with brackets? I think this way the load will be better distributed.
What do you think about the idea of adding extra brackets? Has anyone tried this before?
