ᐅ How can I assemble Malm drawers correctly without errors in the instructions?
Created on: 17 Apr 2021 14:23
brioglaHello everyone, I am currently facing the task of assembling Malm drawers, but I have the problem that the supplied instructions often contain typos that make them difficult to understand. It is often unclear which parts are meant exactly, or the sequence of steps seems contradictory. My question is: How can I assemble Malm drawers without getting confused by the typos in the instructions? Are there any proven tips to avoid such sources of error, or alternative tools that can make the assembly easier? I have already tried reading the instructions very carefully and checking them multiple times, but I still often encounter uncertainties. I would appreciate any helpful suggestions or even a detailed step-by-step explanation so that I can assemble the drawers properly and without mistakes.
JEREMIAH3817 Apr 2021 18:09I know this all too well – those typos in the instructions can be really frustrating, especially when, like me, you get stuck several times while assembling.
What helped me was first carefully unpacking and sorting all the parts, even though the instructions usually don’t suggest this. This way, you get a better overview and can often assign parts in advance. Having a quiet workspace also makes a big difference. I took my time and opened the instructions on my computer to check for typos using search functions or to look up information online.
If you like, I can also offer to go through the steps with you one by one to see which parts are specifically causing trouble. Sometimes, just a second pair of eyes is enough to clear up the confusion. :-)
briogla schrieb:
How do I assemble Malm drawers without getting confused by the typos in the instructions?
First of all, it is important to get a clear and organized overview before starting assembly:
1. Check all components against the parts list in the manual and arrange them in an orderly manner.
2. If there are frequent typos in the instructions, it is advisable to create your own step-by-step list based on the part images and your experience.
3. Additionally, use official IKEA online resources or video tutorials to better understand unclear sections.
4. Pay special attention to the correct orientation of the parts during assembly, as errors in the description often lead to confusion when inserting screws.
This is essential. If you also mark the parts with a pencil, you can minimize mistakes during the process.
If you have specific areas that are problematic, I am happy to provide you with precise instructions or advice.
JEREMIAH38 schrieb:
erst einmal alle Teile sorgfältig auszupacken und zu sortieren
I’m glad to see that some good approaches have already been shared here. I would like to add a few more details since I have assembled Malm drawers for several projects myself and have encountered some common pitfalls that are often worsened by inaccurate or faulty instructions.
First of all, I recommend not relying solely on the instructions but combining them with a video tutorial. There are many good tutorials that clearly demonstrate how to assemble the drawers, including tips on avoiding using the wrong screws or ensuring the optimal positioning of the drawer slides.
A crucial point is understanding the function of the individual components. For example, the side panels of the drawer often differ only slightly but must be installed the right way around, as the pre-punched holes for attaching the front panel and for the guide rails need to be in the correct position.
Personally, I use a small sorting box for screws and dowels to keep them within easy reach during assembly. Additionally, a magnetic pick-up tool is handy if a screw happens to fall.
Finally, if you have the option to scan the instructions in advance or process them with text recognition software, you can correct any detected errors yourself and thus create your own error-free set of instructions.
Could you specify which exact errors or unclear points are causing you the most trouble? That would help provide more targeted advice.
briogla schrieb:
alternative Hilfsmittel, die den Zusammenbau erleichtern?
Hello briogla, I really like your approach – well expressed and precise.
Regarding your concern: dealing with faulty instructions can indeed be frustrating and sometimes discouraging. But with some patience and a systematic approach, it is manageable. From my experience with a similar project, it helps to read each step out loud before starting the assembly. This brings clarity, and you immediately notice if a step doesn’t make sense.
Also, I encourage you to take some time for thorough preparation before you begin: sort the parts, prepare the tools, and create a checklist right away. This way, you can better follow the process and replace possible typos in the instructions with your own notes.
I’d find that interesting too, because sometimes the errors are not just typos but vague descriptions that require interpretation. If you like, feel free to give examples, and we’ll help you step by step 🙂
lorena schrieb:
Could you be more specific about which exact errors or unclear points are causing you the most trouble?
