I’m currently facing the challenge of assembling the drawers of my new IKEA Malm dresser set without causing scratches, dents, or other damage—both to the drawers themselves and the cabinet. Although the instructions are provided, they seem a bit brief in some areas, and I’m especially concerned about damaging the drawer slides or scratching surfaces when inserting them.
I’m particularly interested in which tools and techniques you use during assembly, which areas are especially sensitive, and if there are any tips for installing the drawers carefully and precisely. Are there any special tools that should definitely be used, or additional protective measures to take beforehand?
I have basic experience in furniture assembly, so recommendations on common mistakes to avoid would also be very helpful. Thanks in advance for your advice!
reoWilhelm27 Jan 2018 19:03oralne schrieb:
I’m currently facing the challenge of assembling the drawers of my new IKEA Malm dresser set without causing scratches, dents, or other damageHey – I totally know how that feels! My advice right from the start: patience is key. 😊
Honestly, these Malm drawers are actually quite cleverly designed, but the mistake I often see is rushing too much. Especially when sliding the rails in, you should gently align the parts without applying too much pressure. One tip: a little assembly wax or even a bit of soap on the edge of the rail (not too much!) can make sliding easier and reduce the risk of scratching.
Also: set up your workspace on a soft surface (an old blanket, large towel) to protect the outer surfaces during assembly. If you sort the individual parts beforehand and make a simple plan of the logical steps, you’ll save yourself stress and prevent damage in the end.
Good luck, you’ll definitely manage without any major mishaps! :-)
oralne schrieb:
I’m especially interested in what tools and techniques you use during assemblyHello,
I’m approaching this topic in a structured way – this is how to assemble the Malm drawers without damage:
1. Inspection and preparation: Check all parts for defects before assembly. Clean the wooden surfaces with a lint-free cloth to ensure better adhesion of assembly glue or wax.
2. Installing the drawer slides: The slides must be installed perfectly straight and without any tilting. I recommend temporarily securing the slide with clamps or a substitute for a clamp before fastening it with screws, and aligning it using a spirit level.
3. Protecting surfaces: When working with screwdrivers, always use a soft surface underneath, such as a foam mat or thick cloth, to prevent damage to the material.
4. Inserting the drawer: Pull the drawer slightly forward, hold it steady with both hands, and carefully guide it into the slides. Be aware that the mechanism can be quite tight. Gentle back-and-forth movements can help the slide engage properly without using excessive force.
5. Final check: Open and close the drawers several times to make sure everything runs smoothly and nothing sticks or is misaligned.
Common mistakes include aligning the slides without a spirit level or overtightening screws, which can negatively affect how smoothly the drawer operates. In general, never use force – usually, some adjustment is all that’s needed.
If you like, I can put together a checklist for the individual steps.
GUSTAVO5629 Jan 2018 10:43Guyju schrieb:
I recommend temporarily securing the rail with a clamp substitute (e.g., clips) before screwing it in and aligning it with a spirit level.Very good tip! I would like to add a bit more detail here because Malm drawers are quite sensitive to improper installation:
- Don’t just screw in carefully; first pre-drill the holes (if possible) to prevent the wood from splitting.
- It’s best to use a screwdriver with a torque limiter or at least a cordless drill on the lowest setting to avoid over-tightening.
- Thin felt pads or self-adhesive protective pads at the contact points of the drawer slides can help prevent scratches on the cabinet.
- When installing: The drawer bottom has front and rear guiding rails—make sure the rail is not misaligned, as this can easily cause dents.
- If you’re unsure whether the rail is properly seated: Take a short break and check the alignment several times with a spirit level and possibly a small clamp.
Quick question: Does your Malm version use metal or plastic slides? This can affect the type of installation and potential issues.
If you want, I can also recommend a step-by-step guide with photos, even though I can’t send it directly. It’s worth taking a close look to identify critical areas.
