ᐅ How can the Ikea Brimnes series be expanded modularly?
Created on: 15 Feb 2020 10:37
Joloel
Joloel
15 Feb 2020 10:37
I am currently exploring how to expand the Ikea Brimnes range modularly. Specifically, I am interested in options for practically and functionally supplementing existing furniture from the Brimnes series without having to buy everything new. My focus is mainly on how shelves, cabinets, and possibly bed frames or drawer units can be extended and combined. It would be particularly helpful to receive tips or experiences on how to use storage space more efficiently through additions, without compromising the overall look with mismatched pieces. Additionally, I would like to know if there are practical adapters or specific accessories available from Ikea or third-party manufacturers that make these expansions easier. What approach would you recommend for modular and flexible expansion of Ikea Brimnes? Please feel free to provide detailed explanations and examples from your own experience!
Surela
15 Feb 2020 12:04
The Ikea Brimnes system is fundamentally modular, which means that individual units such as dressers, shelves, or bed frames are technically compatible because many components use standard connectors and a perforated panel system.
I would like to go into detail about expanding storage options: First, you can increase the capacity of existing cabinets by adding extra shelves. Ikea offers separate shelves for Brimnes that can be used as needed. These add flexibility to the interior space and allow for better organization of smaller items.
Additionally, the drawer units in the Brimnes range allow combining different compartments to create more order. One tip for expansion is to mix vertical and horizontal formats – for example, a tall shelving unit next to a wider dresser unit. The dimensions usually match, so the furniture can be placed seamlessly side by side.
Regarding the bed frames, it is important to know that Brimnes bed frames often come with complementary storage boxes that can be slid underneath. These boxes are typically separate storage solutions that make good use of the available space under the bed and can be easily added modularly.
On that note: there are some third-party adapters or accessories available, especially storage boxes and separate organizers that are compatible. The perforated panel system with standard drill holes often allows for retrofitting additional elements, such as inner drawers or dividers.
How much specific accessory do you need? And do you already have products you want to expand? This way, I can address practical challenges more precisely.
Linavin
16 Feb 2020 09:18
An interesting question, which basically assumes that Ikea Brimnes is truly modular in the classic sense.
I would point out that while the system does offer some modular elements, it is by no means a fully developed modular system as you might find from other furniture manufacturers specifically designed around modular concepts.
The main issue I see is that many Brimnes components are designed around standardized dimensions and connections, but these are limited to combinations within Ikea’s predefined product groups. For example, connectors are quite restricted, and there are no official adapters that make it easy to join different modules effectively.
Therefore, I would rather suggest focusing on traditional expansions such as additional shelves, a third drawer, or separate storage boxes, instead of trying to directly combine cabinets.
Also, for modular expansion, alternative systems or complementary products might be recommended to ensure maximum flexibility.
I’m curious if anyone here has successfully expanded Brimnes elements so that different modules work together robustly? Or is it mostly just a visual alignment without real connection?
PERON
17 Feb 2020 20:51
Linavin schrieb:
I’m curious if anyone here has managed to extend Brimnes units so that different modules work together robustly?
From my experience, this works quite well if you use a few tricks. Obviously, the original connection points aren’t really designed for extensive modular assembly, but you can make the individual Brimnes pieces quite stable by using simple methods, such as metal brackets from a hardware store or clamp connectors.
This is especially useful when you have different shelving units placed side by side that should hold together visually and functionally. Such hardware tweaks help, provided you have some basic DIY skills.
Also, I really like combining drawer modules with open shelving units to give a room more flexible storage options – this can be easily expanded step by step. Tip: Using optional under-bed storage boxes for beds is also very worthwhile; they are well sized and make extending the system enjoyable.
My view is this: If you customize Brimnes a bit with some hands-on work, modular expansion works much better than relying only on the standard Ikea accessories. You just need to understand what you’re working with and be willing to make small improvements yourself.
