ᐅ How can I securely mount BILLY shelves on drywall (also known as plasterboard or gypsum board)?
Created on: 5 Nov 2018 13:27
TafarHello everyone,
I am planning to install some BILLY shelves on drywall at my home, but I am concerned about how to securely attach these shelves without them falling off after some time or damaging the wall. The walls are standard drywall panels without a load-bearing framework behind the relevant area.
I am especially interested in which type of anchors or fasteners are best suited to reliably support the weight of the shelves. Are there specific solutions for heavy shelves, or would it be better to use additional reinforcements, like wooden battens behind the wall?
I would also like to ensure the installation itself is stable and secure, so I would appreciate tips on the procedure, appropriate screws, and tools.
Does anyone have experience or recommendations, especially regarding the combination of drywall and BILLY shelves? Thank you in advance!
Tafar schrieb:
Which type of anchors or fasteners are best suitedUse specialized drywall anchors, such as metal toggle anchors or Fischer DUOPOWER. This ensures the shelf will hold securely. Screws should be at least 5 mm (0.2 inches) in diameter.
Tafar schrieb:
Should I rather use additional reinforcements? If possible, screw into the wooden framework behind the drywall, as this is the most reliable method.
Hello Tafar,
It is very important to understand that drywall panels do not have a high load-bearing capacity by themselves. The usual way of mounting BILLY shelves can be problematic when the shelf is fully loaded.
Here are some tips I would give you:
1. Be sure to use suitable anchors for hollow walls, such as metal toggle anchors or special toggle bolts. These distribute the load over a larger area behind the wall.
2. If possible: Try to screw directly into the side wooden studs (the framework behind the drywall). For this, you should use a stud finder to locate the positions of the studs.
3. For heavier loads, you can also fix a wooden batten to the wall (ideally attached to the studs) onto which the shelf can then be screwed.
4. Screws should be long enough, at least 50 mm (2 inches), to ensure a good hold.
5. Distribute the load evenly and avoid hanging everything in one spot.
If you have more details about the material, I would be happy to give you more specific advice.
Germanro schrieb:I completely agree with this and can only emphasize it.
If possible, screw into the wooden framework behind the drywall, as this is the most reliable.
To supplement the previous answers, here are some precise recommendations:
- The load-bearing capacity of drywall (gypsum board) walls for point loads is limited. A BILLY shelf, especially when fully loaded, can quickly apply over 20–30 kg (44–66 lbs) per attachment point.
- Metal toggle anchors (also called cavity metal anchors) are the safest choice when fastening directly to drywall. They expand behind the wall and distribute the load.
- It is advisable to use at least three attachment points per shelf to properly distribute the load.
- If the wall is built on a wooden stud frame, you will achieve the best hold by using thick chipboard screws (4.5–5 mm diameter, at least 50 mm (2 inches) long) anchored into the studs.
- Alternatively, a support batten (a sturdy wooden strip with a sufficiently large surface area) can be attached to the studs, allowing the shelf to be securely fixed to it.
- If you cannot screw into the underlying structure, high-load toggle anchors are mandatory, and screws of the correct length should be used (at least 40 to 50 mm (1.5 to 2 inches)).
- Avoid longer shelves that are hung only on drywall without any wooden substructure behind.
- Screws and anchors from reputable manufacturers in building supply stores are crucial for reliability.
If you want to be absolutely certain, you can test the load capacity with a small trial before fully loading the shelf.
