ᐅ How can I repair MALM drawer hooks?
Created on: 6 Jun 2017 07:36
Maumarei36
Maumarei36
6 Jun 2017 07:36
I have damaged the drawer hooks on my IKEA Malm bed, which attach the drawers to the side rails. Specifically, some of the small plastic hooks have torn out or broken, so the drawers no longer hold properly when pulled out and sometimes fall completely out.
My question is: What options are there to repair or replace these Malm drawer hooks without having to replace the entire drawer? Are there replacement parts, DIY tips, or specific adhesives/materials that work?
I would appreciate detailed advice, as I want to maintain the stability and functionality of the drawers as close to the original as possible, rather than just making a temporary fix.
V
van_pe
6 Jun 2017 08:11
You can order replacement hooks directly from IKEA; sometimes they still have these parts available as spare components.
Alternatively, superglue can help if the break is clean and the hooks are not completely broken off.
gekira
6 Jun 2017 09:05
The MALM drawer hooks are made of brittle plastic that can crack after extended use.
A repair with superglue only works if the broken parts fit tightly together and there are no large gaps. It is important to apply the glue sparingly and let it cure for at least 24 hours after fixing.
Alternatively, you can try ordering replacement hooks from IKEA. If these are not available, some online retailers or forums occasionally offer compatible aftermarket parts.
A DIY solution is to reinforce the hook with thin wire or small metal strips, or to shape it with epoxy resin to improve stability. However, this requires skill and precision, as otherwise the drawer mechanism may become misaligned or jam.
sarGabriel
6 Jun 2017 10:22
I repaired my hooks with hot glue, and it holds surprisingly well.
First, clean the broken area, then carefully apply hot glue and shape it briefly.
Maumarei36
7 Jun 2017 06:46
Thanks, I will give that a try.
gekira schrieb:
A DIY solution would be to reinforce the hook using thin wire or small metal strips
Could you explain that in more detail? I find it hard to imagine how to reinforce such delicate plastic hooks without affecting the drawers’ correct locking function.
For example, could you drill small holes in the broken hook and then thread or glue the wire through them? Or am I missing important aspects, such as material stiffness and fit accuracy?
gekira
7 Jun 2017 11:17
Your considerations are correct; filling small drill holes and inserting thin wire is a possible method.
You should use very fine drill bits (around 1mm (0.04 inches)) and secure the wire (about 0.5–1mm (0.02–0.04 inches) in diameter) as close to the plastic as possible with adhesive. Epoxy resin works well here because of its adhesion and stability.
It is important that the repaired hook does not become too thick, or the drawer will catch. Therefore, it is better to use several thin wires in parallel.
Alternatively, you can also glue a thin metal or plastic pin as a core into the break and apply some resin or plastic over it to recreate the shape.
This requires some time and finesse, but it is feasible for experienced DIYers.
