ᐅ How can I make BILLY shelves more stable when used in an office?
Created on: 14 Aug 2021 08:43
Fifu56Hello everyone,
In our office, I use several IKEA Billy bookcases, mainly for binders and various work materials. Unfortunately, I have noticed that over time the shelves become quite wobbly – even when they are secured to the wall, you can tell they are not very stable when heavier loads are placed on them or if they are bumped.
My question is: What can I do specifically to increase the stability of the Billy bookcases when used in an office environment? Are there proven methods or simple modifications that make them significantly sturdier? I would prefer not to buy completely new furniture but am looking for practical solutions that can be implemented without much effort.
Thanks in advance for your tips and experiences!
Hello Fifu56,
I’m happy to provide a more detailed guide on how to improve the stability of your BILLY shelves:
1. Wall Fixing: Check whether the supplied screws and wall plugs are suitable for your wall type. For drywall, special cavity anchors are helpful; for concrete or brick walls, heavy-duty anchors are better.
2. Reinforce the Back Panel: The thin back panel of the BILLY is often a weak point. Have you considered replacing it with a more rigid board, such as a thin OSB board or MDF? You can screw or glue this from the inside. This will significantly increase the shelf’s resistance to twisting.
3. Additional Metal Brackets: Metal brackets screwed inside the frame dramatically increase stiffness. You can attach these either at the corners or midway along the frame.
4. Connect Shelves Together: If you have multiple BILLY units placed side by side, connect them with brackets or screws. This makes the entire shelving system more stable and better distributes loads.
5. Level the Base: Make sure the shelf stands firmly and does not wobble on the floor. Small furniture wedges or anti-slip pads on the feet can help with this.
I hope these tips are helpful. Feel free to ask if you have any questions!
PAR63 schrieb:
A stiffer panel (e.g., a thin OSB board or MDF) instead of the original back panel... makes the shelf much more torsion-resistant.I agree with that, but I wonder if it changes the appearance of the shelf too much. The original back panel is usually thin and white, while an OSB board looks quite rustic. Does anyone have experience with balancing functionality and design in this regard?
Also, I'm skeptical about whether gluing the back panel will hold up permanently, especially under office load. What do you think about mechanical cross braces made of metal as an alternative?
Looking forward to more opinions, preferably with solid arguments, since I’m not really keen on relying on gut feeling alone.
I would like to address Linavin’s design question and offer some practical tips on how to improve stability without significantly changing the appearance.
Regarding the back panel: many people now use thin MDF boards instead, which can be easily painted white or laminated. This keeps the shelf looking very close to the original. You can also fix the MDF board with screws, which provides more security than just gluing it.
As an alternative, metal braces are also useful – for example, flat metal brackets that can be installed horizontally or diagonally inside the shelf. Although they are somewhat visible, you can also place them out of sight, such as at the back, top, or bottom, where the shelves usually rest against the wall.
I had a similar issue in my office. Only the combination of secure fastening with heavy-duty anchors and a replacement back panel fully eliminated the wobbling problem. The load from binders is then well distributed.
Good luck implementing this! If needed, I can also recommend some sources for suitable boards and brackets.
Thanks in advance for the many helpful responses!
This is exactly where I’m a bit stuck: Is it better to glue the back panel or screw it in? And if screwing, how close to the edges of the panel should the screws be placed to avoid tearing?
How do you handle this exactly with BILLY shelves? Do you need to pre-drill, or can you directly screw into MDF with standard screws? My concern is always that the panels might crack or warp.
Your experiences are important to me because I want to upgrade some shelves without immediately calling a professional carpenter.
islaron schrieb:
Gluing back panels or reinforcing them with OSB boards can also help.
Laurence schrieb:
also secure the MDF panel with screws, which provides more security than just gluing.
