ᐅ How can I better protect Billy shelves from sun exposure?
Created on: 9 Jul 2024 10:07
Henrik67
I have a question that has been on my mind for some time: How can I better protect my Billy shelves from sunlight exposure?
The shelves are placed directly by the window, where a lot of daylight comes in, and I notice that the surface gradually fades and becomes slightly brittle. I want to prevent any damage to the shelves or permanent discoloration. Are there effective methods or materials to protect the wood or surface from UV rays?
I would appreciate any ideas or experiences!
neoren
11 Jul 2024 14:37
Henrik67, I would recommend buying simple UV-protection curtains. They are specifically designed for this purpose, blocking UV rays and protecting furniture. Additionally, you can open or close them depending on your light requirements.
Alternatively, there are also roller blinds with UV protection if you want something a bit more flexible.
flo-Theres
12 Jul 2024 08:53
One important point that hasn’t been discussed in detail yet is the material of your Billy shelves. If your shelves are made of relatively thin particleboard with a foil coating, they will be more sensitive to UV exposure than solid wood with paint.
With that in mind, UV protection films on the window or UV-blocking curtains are probably the most effective measures without much effort.
If you are thinking long-term, it might also be worthwhile to treat the shelves with special UV-protective varnishes suitable for laminate. However, make sure these varnishes are intended for home use, as not every varnish adheres well to foil surfaces.
In conclusion: a combination of distance from the window, UV protection, and occasional repositioning provides the best protection.
