ᐅ How can I adapt BILLY shelves to different room sizes?
Created on: 2 Jan 2021 10:23
frankobe
frankobe
2 Jan 2021 10:23
I have been thinking about how to best adapt IKEA BILLY shelves to different room sizes, as I have individual rooms in my apartment with very varying dimensions. I am particularly interested in what adjustments in terms of width, height, depth, and assembly are possible without having to buy completely new shelving systems. Are there flexible options, such as additional parts or rearranging the shelves? And how can the shelf be configured to fit into small niches while still looking good in larger rooms? I’m looking for practical tips, preferably supported with examples, as I don’t always find the technical descriptions on the IKEA website fully intuitive.
PRABAU
2 Jan 2021 11:02
The easiest way to customize the BILLY shelves is by choosing different combinations of width and height. For example, there are versions with widths of 40, 80, and 120 cm (16, 31, and 47 inches), as well as various heights ranging from 106 to 202 cm (42 to 79 inches). You can also use shelves in between to adjust the interior layout to your needs.
Guyju
2 Jan 2021 13:45
Here is a brief guide for adapting BILLY shelves to different room sizes:
1. Measure and plan the space: First, accurately determine the available area. Note the width, height, and depth of the niche or wall space.
2. Select shelf types: IKEA offers BILLY shelves in standard widths of 40 cm and 80 cm (16 inches and 31.5 inches), with a narrower 28 cm (11 inches) option rarely available. Heights range from 106, 147, to 202 cm (42 inches, 58 inches, to 79.5 inches). Depths are usually 28–30 cm (11–12 inches), which works well in smaller rooms.
3. Combine shelves: For wider spaces, place multiple shelves side by side to create flexible widths. Shelves can also be stacked by securely fixing them or using suitable cover panels.
4. Adjust the interior fittings: Use the removable and adjustable shelves to optimize the unit for smaller or larger items.
5. Use accessories: Some IKEA parts like doors or drawers change the look and help adapt the unit to different room situations.
A common mistake is using just a single shelf, which can make the room feel either overcrowded or underfilled. A modular setup with flexible combinations works better.
Hope this helps as a starting point.
lomin
2 Jan 2021 15:09
I completely understand that standard dimensions don’t always fit well, especially when rooms have irregular shapes or niches are very narrow. It often feels quite limiting.
Guyju schrieb:
You can also stack shelves on top of each other by securely fixing them or using suitable cover panels.
That sounds almost like a good solution! Have you tried that yourself? I’m a bit concerned that the construction might become unstable when stacking or combining shelves. Maybe someone can share their experience on how to do this safely?
I’m also interested in whether the back panels of BILLY can be easily modified when placing shelves in smaller niches. Sometimes the back panel is too wide or doesn’t sit flush against the wall.
Joshbe
3 Jan 2021 09:17
Regarding stability when combining BILLY shelves: IKEA offers official connectors (brackets) that allow you to securely join two shelves. These create a stable unit, even when shelves are stacked or placed side by side.
lomin schrieb:
I am a bit worried that the construction will become unstable when stacking or combining shelves.
This concern is valid if no connecting elements are used.
As for the back panels: BILLY typically comes with thin hardboard panels as backing, which can be trimmed or cut with some basic DIY skills. For a better fit in niches, you can have alternative back panels custom-cut to the required measurements or simply omit them if the space allows.
Recommendation: Measure carefully, then choose shelves with suitable heights and widths, purchase connectors, and adjust back panels if needed. This way you achieve maximum flexibility.
