ᐅ Home Construction Providers in Baden-Württemberg
Created on: 5 Jan 2020 13:36
dahjen87
we are looking for an affordable house builder (prefabricated house or solid construction) in Baden-Württemberg.
Do you have any recommendations or experiences?
The focus is on price, but the quality should also be good.
We look forward to your feedback.
erazorlll
23 Jan 2020 13:21
We are currently looking for a contractor in the Böblingen district for a semi-detached house. The only difference compared to the post above is that the site has a slight slope.
Has anyone had any experience in this area? Advice from consultation meetings would also be helpful for us.
11ant23 Jan 2020 13:30
erazorlll schrieb:
We are currently looking for a builder in the Böblingen district for a semi-detached house.
For the general search for a builder, you can find plenty of threads here. Specifically for a semi-detached house, I would strongly recommend using the same builder for both halves, as this minimizes complications with alignment and coordination.
erazorlll
23 Jan 2020 13:36
Especially for a semi-detached house, I would clearly recommend: use the same one as for the other side, as this minimizes complications when fitting them together.
That would have been my preference as well, also to save on travel and other costs. Unfortunately, the other side of the property has not been sold yet, and there is no indication of when that will happen. We will now proceed with the usual house planning and discussions. If a sale occurs in the meantime, coordination will be necessary. Otherwise, we will probably just build on our side for now.
tomtom7923 Jan 2020 15:12
How do you plan to build on a 16 x 22 m (52.5 x 72 ft) plot if you are only allowed a 0.4 building coverage ratio? That only permits a maximum footprint of 200 m² (2,150 ft²).
11ant23 Jan 2020 15:24
erazorlll schrieb:
Unfortunately, the other side of the plot has not been sold yet, and there is no indication of when that will happen. [...] If not, we will probably just build on our side for now.
I don’t want to go into this in detail in a thread started by someone else. But take a look around the forum. A lot has already been written about semi-detached houses, including my opinion (with reasoning) and opposing views (some also backed up with explanations) thoroughly discussed. You probably can’t miss the thread by @goalkeeper either, which tells the story of a builder whose project is now well advanced, and who was later surprised by having to include a third house as an additional unit. Planning a semi-detached house in uncertain conditions is a challenge for anyone. I recommend using the search terms “11ant Doppelhaus” and “Mitkellerer” for some early discouragement.
goalkeeper
23 Jan 2020 16:15
Don’t let yourself be unsettled. Build your house exactly the way you envision it. If the other semi-detached house gets built later on, they will have to adapt to your design. Ideally, build a basement. This way, no underpinning by the neighbor will be necessary later on – if you build with a slab-on-grade and the future neighbor has a basement, it will simply be much more expensive for them.
Regarding the cost of the basement: it will likely cost you at least 60,000 euros (about $65,000) – depending on how much material you need to dispose of or not. In our building area (northern Baden-Württemberg), basement builders pay between 40 and 70 euros (about $43 to $76) per ton for disposal.
