ᐅ Heat Pump Connected to Household Electricity or Separate Supply? How to Calculate?
Created on: 9 May 2016 22:57
tabtab
I am currently trying to work out whether it is worthwhile to connect the air-to-water heat pump to the main household electricity meter or to save money using the heat pump tariff.
Since both the heating electricity tariff / heat pump tariff have a peak rate (HT) and an off-peak rate (NT), the question is how much consumption I can expect at which times. For example: the off-peak rate starts at 9 p.m. and lasts for up to 8 hours. So, I need a rough estimate of how much electricity the heat pump consumes annually under the off-peak tariff.
How can I find this out? So far, I have assumed a total consumption of 2,500 kWh, with 1,500 kWh on the peak rate and 1,000 kWh on the off-peak rate. This was just a rough guess. I would prefer to have a more accurate estimate.
Do you have any reference points?
Caspar202010 May 2016 14:42If you Google "verivox heat pump," you will find a comparison tool specifically for tariffs that allow heat pumps. You can also choose between one or two meter solutions.
For our postal code, there are about 10 to 20 alternatives.
I have seen that as well regarding the tariffs. However, the tariffs ask for the kWh amounts in each category. That’s why I wanted to know how the consumption is usually distributed. I have a tariff where household electricity costs 21 cents and heat pump electricity costs 16.x cents – excluding the basic fee. The question is whether this is worthwhile. I guess I’ll have to break out the calculator then. Besides a second meter and possibly a second provider… are there any other disadvantages or advantages?
Sebastian7910 May 2016 17:10The rates at Verivox are based on having a separate meter – therefore....
Here are 3 links on the topic
https://www.hausbau-forum.de/threads/Wärmepumpe-an-sep-zaehler-oder-zusammen-mit-Haushaltsstrom.15242/
https://www.hausbau-forum.de/threads/Kombination-aus-luftwaerme-pumpe-und-wasserfuehrenden-Kamin.13976/
https://www.hausbau-forum.de/threads/solar-pv-wirtschaftlicher-Gesichtspunkt.13659/page-4
Caspar202010 May 2016 17:49Sebastian79 schrieb:
The rates at Verivox are based on having your own meter – just so you know.I was able to choose between tariffs for one or two meters.
Sebastian7910 May 2016 19:12Now think carefully again about what is meant by this.
