I know this is probably a silly question, but I really have no clue right now. In the past, I used to just hammer nails into the walls.
By now, I’ve become a bit more cautious about it. If I want to change positions later, I’d end up with lots of small nail holes in the walls.
How do you handle this? We have wallpaper. I’ve read about nano tape, which is said to hold pictures very securely, but opinions are very mixed on how well it can be removed.
I also don’t want to avoid a nail hole only to end up with a tape strip-sized hole in the wallpaper.
At some point, it's time for the first hole in the wall 😀
Small (nail) holes can easily be covered with paint. If needed, apply a bit of filler beforehand.
Schimi1791 schrieb:
At some point, it’s time to make the first hole in the wall 😀
Small nail holes can easily be filled with paint. If needed, apply a bit of filler first. Here comes the next problem – I have leftover paint (the wall is not white) in a bucket up in the attic. What’s the best way to store it? Is it true that it should be kept away from light?
The wall isn’t protected from light either, so if I repaint in a year, might there be a visible color difference?
Nida35a schrieb:
The first nail holes and plugs in a new house are always tough,
usually hanging the next picture on the same nail helps,
or alternatively a little higher – then the hole just disappears. I’ve already made my first mistakes. I hung some long pictures quite high, but then I didn’t like them there. Now I want to hang square pictures instead. Hanging them on the same nail makes them too high. And if I hang them lower, I end up with 6 nail holes above the new pictures. 🤨
Tolentino schrieb:
That’s what the favorite person is for, holding the pictures on the wall until their shoulders burn... I thought about that too at first, but then I’d have to change the kid’s diaper myself. :P
