ᐅ Patio slabs instead of grass – challenging conditions
Created on: 8 Jan 2017 22:59
FelixPrüfer
for 2017, we are planning to transform our garden into a "courtyard."
Here’s the situation: We spend a lot of time in the garden. When we go outside from the terrace, there is grass – or rather, there used to be grass.
We have small children and go outside in all kinds of weather. Now we want to create a courtyard with slabs (not paving stones) so that the children can comfortably ride vehicles like pedal tractors – meaning a relatively smooth surface. Besides, we don’t really like paving stones; slabs look nicer to us.
This wouldn’t be a problem, if it weren’t for some circumstances that complicate everything:
1: You can easily spend 100 euros per square meter on the subbase. For 120 m2 (1,292 sq ft), this is simply too expensive for us; we need a more affordable alternative. We are trying to buy used slabs and want to save money on the subbase because
2: The garden cannot be accessed by lorries. A small mini excavator can get in, but that’s it. So even if we wanted a subbase of about 40 cm (16 inches), disposing of the excavation material would be so complicated and costly that it doesn’t make sense.
I have researched online for a long time and have an idea how a subbase with just a few centimeters might work: There is a company that sells plastic grass grid pavers as a base for paving, which they recommend.
This way, you avoid excavating deeply.
Has anyone tried this before? Does anyone have ideas on how we can create a smooth, clean, stable courtyard from grass/mud without deep excavation and without spending 10,000 euros?
Maybe there is an option I haven’t thought of yet.
Thank you very much for your helpful ideas!
Felix
Gartenfreund
10 Jan 2017 01:47
Hello FelixPrüfer
My father installed the driveway with colorful slabs back in the 1960s, which was quite modern at the time. It was a DIY project using just some sand to level out the unevenness beneath the slabs, and despite this, it held up very well. After a new driveway was built, the slabs were reused for several years as a garage floor because the old concrete slab had to be removed since the new driveway is lower than the old one. Later, my father decided to have a concrete floor again, so these slabs were then used, among other things, for a walkway. The size of the slabs varies. I don’t have the exact measurements in mind right now and can’t measure them at the moment since it’s a bit dark outside and also still raining. But I can provide the measurements later. I placed the slabs as close together as possible. They are laid so tightly that even weeds have difficulty growing between them.
