ᐅ Insulating the Garage Roof – Roof Sealed with Bitumen Membrane
Created on: 15 Aug 2018 19:30
Bauherr_0877
Our house dates back to 1962, and the garage roof expands slightly due to heat from the sun in summer. This causes cracks in the walls and prevents us from plastering the walls.
I want to protect the roof from the heat (sun) and am looking for ideas.
Currently, I am considering two options: either protecting it with gravel or, more complex and expensive, with a green roof for the garage.
Does anyone have other ideas or experience with these two options?
At the moment, the roof is sealed with roofing felt.
Thank you very much
Wickie
17 Aug 2018 11:22
We have also been given the prices. In our case, parts of the house (flat roof) must be greened. We are still considering whether to do it ourselves, but I don’t find it that easy. Just getting the aggregate spread on there in the right thickness alone...
Alex85
17 Aug 2018 11:32
Have it done properly right away. Otherwise, you'll have too much unwanted growth, and the seeds need to be watered regularly—how do you plan to manage that?
Wickie
17 Aug 2018 11:40
This is actually very simple. The basement is larger than the upper floor, and at the spot where we want to add greenery, I can easily access the roof from my bay window to water and pull weeds 🙂 So that point doesn’t worry me. We were already aware of that.
We’ll see. The roofer’s prices were quite outrageous, and the landscaper starts work in the garden on Monday and, to my knowledge, also offers something like this. I’ll contact him again regarding prices...
niri09
17 Aug 2018 11:45
I would go with ready-made sedum mats right away, so you don’t need any substrate granules. You only need gravel for the edges, but of course, you still have to carry everything up yourself. I calculated that if you do it yourself, the cost is around 200–300€
Müllerin
17 Aug 2018 15:23
Since our roof area is 60m² (650 sq ft), we won’t be doing it ourselves. It probably won’t happen this year either, as everyone is fully booked 😉 .
I don’t have to pay for the root barrier layer; the roofer is unintentionally covering that cost because he made a mistake and didn’t weld the correct bitumen membrane 😉
So, I need aggregate and soil mixed with seed mixture.
I have looked at those ready-made mats for planting. It might be simple to use them, but I don’t want to have that much waste on the roof – the mats are made of plastic forms.
andimann17 Aug 2018 16:24
How do you arrive at these prices? I was quoted around €80 per square meter (approximately $85 per square yard) for the installation alone, and the materials alone cost about €40 per square meter (approximately $43 per square yard).
We have over 30 square meters (approximately 320 square feet) of carport area, which we are legally required to green. If there is a cost-effective solution, I would appreciate any tips.
Andreas
