ᐅ Floor Plan Ideas for a 1500 sq ft Single-Family Home
Created on: 16 Dec 2013 18:09
Z
Zeiti
After 10 months, we (my wife, daughter, and I) are now focusing more intensively on our building project.
We have received several offers by now. Since the floor plan I created myself had to be slightly adjusted by the architect due to structural requirements, I would like to get some suggestions from you.
It is very important to us to build naturally. Therefore, we have been in contact with several local timber construction companies. We plan a single-family wooden house with natural insulation materials (KfW 70 standard, preferably better), a basement with a separate entrance, pellet heating system, and a photovoltaic system. Approximately 140 m² (1,507 sq ft) of living space (we plan 3 children, one is already here at a proud 2.5 years old).
Half of the attic (up to the middle wall) will be available as an attic storage area, accessible via a retractable staircase in the hallway. The other half (above the children’s bedrooms) will partly have an exposed roof structure and partly a ceiling. The covered part will be accessible with the help of a step ladder and serve as a play and storage area.
Now to my main questions:
Basement utility room:
- Should the washing machine/dryer remain in the utility room, or as originally planned, be located in the shower/toilet room on the ground floor?
I need about 6-7 m³ (212-247 cubic feet) of space for pellet storage (this volume was sufficient for about 16 months in the house of my father). The rest of the room should be free for the heating system (so approximately 13.5 m² / 145 sq ft remain).
Living/dining room on the ground floor:
- Should the door to the hallway be moved about 1 meter (3 feet)? The idea is that moving it would give me more space for the TV wall/bookshelf.
- Should the wall next to the fireplace be aligned flush with the upper wall, meaning moved 30 cm (12 inches) to the left and shortened by 60 cm (24 inches) at the same time? According to the architect, this is doable and would open up the space.
- Should the kitchen be shortened by one unit (60 cm / 24 inches)? This would make room for, for example, 2 bar stools for a quick breakfast (a wish from my wife). There would still be enough space for the dining table, which would be moved into the corner with a corner bench.
- Large window area: double French doors or sliding doors? (In my opinion, double French doors would be more practical and cost-effective.)
Children’s rooms upstairs:
- Where should the ladder to the play area be placed? Fixed or movable?
Outside:
- Should the entire corner be clad with rusticated cladding or only the upper half? We are completely undecided.
- Windows made of larch wood or colored uPVC? (Clear wood would cost me almost 5,000 more, but we are still unsure.)
If anyone has questions or suggestions, please feel free to share.
Zeiti
Wastl
26 Dec 2013 22:11
Your fireplace is in the basement, in the hobby room. The heating system is planned for the boiler room. Wouldn't it make sense to swap the two rooms?
Regarding the fireplace in the living room: have them install a large flue (a double flue or whatever is needed), and you can always add a wood-burning stove upstairs later. The double flue shouldn’t increase the cost that much.
Z
Zeiti
26 Dec 2013 22:25
Switching the rooms is not that easy, since my pool table will go into the hobby room and the dimensions are quite fixed.
To be honest, I still don’t know exactly how it will look in reality. I should take a closer look at a few houses.
A double chimney flue was originally planned.
The idea of installing a wood-burning stove later on is actually not bad. Thanks, @Wastl.
By now, we are leaning more towards a pellet burner in the basement.
And the later installation of the wood-burning stove would be possible.
I’ll have to discuss it with my wife. 😉
