Our house will undergo a complete renovation and an additional storey will be added. For the renovation, most of the existing walls will be retained.
For the renovation, all walls up to the bottom edge of the new window height will be removed, then a ring beam will be installed, and the additional storey will be built using timber panel construction. The existing brick walls will be insulated with wood wool and will receive a rainscreen facade made of standing seam steel sheets (which is cheaper than zinc sheets?). The goal is to achieve KfW 55 energy standard or better.
The ground floor slab will be insulated and fitted with underfloor heating. The basement stairs will be extended by one step, allowing about 25 cm (10 inches) of height for this.
In the attic, the sloping roof surfaces are suitable for wall heating.
The children's rooms have a gallery accessible via a ladder. They can only be reached through the ground floor. This makes the parents' area more private and may allow the house to be divided into two separate units in the distant future.
The living and dining area is compact. The front door will be glass to enjoy the evening sun (there are currently no windows on the west side, which is often a shame). The entrance is far enough from the street that this should not be an issue.
Basically, we also wondered if rebuilding would be more sensible. At the moment, I’m leaning more towards renovation.
Construction is not planned before 2025. We are not in a hurry as the children are still small and we have enough space for now.
(The site plan is oriented to north)
Plot size – 1040 m² (11200 sq ft)
Slope – Slight, about 1.50 m (5 feet) drop
Site coverage ratio – 0.25
Floor area ratio – 0.4
Number of storeys – 1.5
Roof shape – free choice
Architectural style – free choice
Orientation – existing building
Architectural style, roof shape, building type – renovation and additional storey of the existing building
Basement, storeys – half basement, 1.5 storeys
Number of occupants, ages – 2 adults + 2 children (4 & 2 years)
Space requirements on ground and upper floors – Ground floor: 85 m² (915 sq ft), Upper floor: 55 m² (590 sq ft)
Office use: family or home office? – full-time and part-time home office
Occasional overnight guests – few
Open or closed floor plan – open living space
Conservative or modern construction – modern
Open kitchen, kitchen island – yes, yes
Number of dining seats – 4 to 6
Garage, carport – available
Utility garden, greenhouse – possibly later
Large cistern with rainwater harvesting integrated into the house
Central mechanical ventilation with heat recovery – as some neighbors like to use their fireplaces, plus other benefits of this system
Photovoltaic system fully covering north and south roofs
Basement must be newly insulated
Clay plaster for interior finishing
Planned by: myself
What do you especially like? Why? The additional storey keeps the house compact
What do you not like? Why? – Everything is fine so far
Estimated budget according to architect/planner – no quotes obtained yet
Personal price limit for the house including fittings: 400,000 (less would be better)
Preferred heating technology – heat pump with horizontal trench ground collector
If you had to give up anything, which details or expansions
- could you do without:
- could you not do without:
Why was the design developed this way? For example:
- based on the interior walls of the old house
- we switched from an extension to an additional storey because it is cheaper. The view from the master bedroom is much nicer now than it would have been with an extension.
What is the key/essential question about the layout, summarized in 130 characters?
Do you see any problem I might have overlooked? Your honest opinions are usually direct but very helpful :-)
Planned by: myself
hanghaus2023 schrieb:
The bathtub right next to the knee wall? How is anyone supposed to get in there? Where there is enough headroom for a toilet, there is also enough for the bathtub.
I don’t think the house is that small, either.
However, I have two questions:
Who makes the children’s beds upstairs?
And
What do you do in the bedroom with a panoramic window wall? I already find frameless designs on upper floors quite “interesting,” but then having it along the entire side, so you don’t even have a low wall behind which you can hide from outside views when you’re undressed… apparently even facing the street. It’s stylish for sure – but I wouldn’t want to live there.
I am not a structural engineer, but I think you would need one. From what I understand, you want to remove some walls on the ground floor. In our new build, we also have a very large open-plan living area, and we had to have the structural calculations done separately and pay a considerable additional cost for more steel reinforcement in the concrete slab to make this structurally possible. In the original plan, we had a support column next to the kitchen island.
hanghaus202313 Feb 2023 15:05ypg schrieb:
Where there is headroom for a toilet, there will also be enough space for the bathtub.I have marked the 2 m (6 ft 7 in) line. However, standing urination is necessarily not possible there.alles3d schrieb:
For the full renovation, all walls will be removed up to the new window header height. Then a ring beam will be installed, followed by a timber frame extension. The existing brick walls will be insulated with wood wool and covered with a rainscreen facade. This all sounds to me very much like "a layperson reading about stylish, impractical ideas on the internet," and such concepts regularly fail during financing discussions (which, put kindly, is “not to the detriment of the project goals”).
I agree with the suggestion to share the existing plans and photos of the house as well as create overview plans, and I suspect it might be a bungalow. Extending the design with the basement stairs located in the corner is a serious disadvantage for the floor plan. With accurate data about the existing structure, more convincing solutions can be found. Economically, this kind of “renovation” would be a costly Pyrrhic victory ;-)
Hello and thank you for the replies.
11ant schrieb:I’m not fully convinced that a renovation is necessary when a new build costs only 50k more. It’s not like a new build would be available for 450k if I base it on my floor plan.
Economically, this "renovation" would be a costly Pyrrhic victory ;-)
kati1337 schrieb:No construction will happen without an architect and structural engineer. But it will be a wooden ceiling and should be feasible.
I’m not a structural engineer, but I think you’d need one.
ypg schrieb:If I can’t manage the furniture staircase anymore (thanks, Sol), then the kids should be old enough to do it themselves. The panoramic window works because the street is far enough away and our area is very quiet and green. The view is really worth it. Right in front of us are only trees; left and right there is a house on the opposite side of the street.
Who will make the kids’ beds upstairs?
What do you do in the bedroom with a panoramic window?
ypg schrieb:The toilet can be moved further forward, but peeing standing up is not an option. That’s no problem.
Where there’s enough headroom for a toilet, there’s also room for the bathtub.
hanghaus2023 schrieb:I’ve attached a sketch of the staircase. It should work. There would be room for one more step.
Are there pictures and plans of the existing building?
hanghaus2023 schrieb:I know, it was just for me. But I thought it might still be helpful.
If you’re already planning yourself, then please do it properly. Demolition is shown with yellow dashes, new build in red, and existing original parts in black.
hanghaus2023 schrieb:Please ignore the outer line. In the end, it depends on the construction of the required insulation with a curtain wall facade.
70 cm (28 inches) external walls on the ground floor?
hanghaus2023 schrieb:What would be a more affordable facade alternative?
Standing seam (metal) cladding is a very expensive facade and roofing option.
SoL schrieb:A holiday home is a nice place to relax; that’s exactly what we want for our house. But seriously, it brings the evening sun into the house, and we really miss that.
The missing entrance area and absence of a cloakroom are more typical of a small holiday home than a family house.
Schorsch_baut13 Feb 2023 16:49Wood beam ceilings require substantial support beams with appropriate bearings for such spans, or multiple columns. Large, open spaces are easier to achieve with concrete slabs.
