ᐅ Experiences with Furniture Paint on KALLAX After Scratches from Keys
Created on: 22 May 2021 07:34
mujedi
I have a KALLAX shelving unit from IKEA at home and wanted to ask if anyone has experience with furniture lacquer to fix scratches caused by keys or other objects on the surface.
Specifically, I’m interested in how well the surface can be restored to a smooth and color-consistent finish after treatment with furniture lacquer, without the repair being immediately noticeable.
Which products would you recommend? Are there certain techniques you think work better than simply repainting?
Also, how durable is such a lacquer in everyday use on frequently used furniture like the KALLAX?
I look forward to your tips and experiences, including whether the effort is really worth it or if other repair methods might be better.
mujedi
23 May 2021 07:02
SauDietmar schrieb:
Sanding, applying thin layers of paint, intermediate sanding, polishing
Thank you for the detailed instructions!
Did you use a specific type of paint? I understand there are differences between acrylic paint, synthetic resin paint, and other types. In your experience, which paint works best to achieve the exact white KALLAX surface?
Also, how long does the entire process usually take before the piece of furniture can be used normally again?
barda6
23 May 2021 08:18
Make sure the paint dries quickly and cures well.
For minor key scratches, touch-up pens are often sufficient if the surface is not deeply damaged. Otherwise, definitely apply the paint in several thin layers.
LAYNE
23 May 2021 09:47
Hi everyone,
I believe the fun factor in furniture paint repair shouldn’t be underestimated. 🙂 With the right paint, a bit of patience, and a good brush, you can really get creative and be proud of the result in the end.
One more tip: once the paint is dry, gently go over it with wax or polish. This gives the surface a smoother finish and provides protection.
Good luck to you all!
anken
24 May 2021 06:39
Deandre schrieb:
Made with touch-up sticks designed specifically for furniture
That’s a useful tip. Additionally, it should be noted that touch-up sticks only cover surface scratches. They are not suitable for a permanent repair in case of actual paint damage.
Also, the color shade of touch-up sticks often does not match perfectly, which can be quite noticeable on white KALLAX units.
SauDietmar
24 May 2021 12:01
I used a white acrylic paint designed especially for furniture. It applied very smoothly but required patience to apply several thin coats.
mujedi schrieb:
How long does the entire process take?
That depends on the product. I allowed about 2 hours drying time per coat and applied a total of 4 coats. Between each layer, I lightly sanded and then polished. The whole process took approximately 1 to 2 days, depending on drying times, before it could be fully used.
Important: Don’t apply the paint too thickly, or you risk runs and an uneven finish.
