ᐅ Electrical Installation – Is Everything in Order?
Created on: 23 Apr 2018 13:53
SimKN
This is my first post in the forum. I have mostly been reading as a guest in the past to gather information on various topics. Now, I’m hoping to get some feedback because I’m really unsure.
We moved into our new end-of-terrace house near Singen (Htw) at the end of February and are mostly satisfied. However, I’m concerned about the electrical installation:
In our electrical panel, we have three fuses, and I have had to replace one of them several times (two were 10 A fuses, which were replaced by 16 A fuses, and one was a 16 A fuse). This past weekend, for the first time, a 16 A fuse blew, so nothing worked anymore. Unfortunately, I don’t know when it happened because we only noticed it in the morning while showering—no hot water, since the heat pump had no power.
I then looked into the distribution box and removed the cover behind the fuses. You can see the result in the attachment.
What do you think? Is this common or is it poor workmanship? I have no knowledge of electrical work, and the local electrician only said the measurements are all good and that everything else is just cosmetic... is he right?
Thanks in advance for your feedback, I hope you can help me a bit.
SimKN
Electrical control cabinet with many wire cables, terminal blocks, and fuses.
Bieber0815
21 Jun 2018 23:40
It doesn’t matter. You need your own expert, one that you have commissioned and paid for. It’s just you and the expert, no developer and no subcontractor involved. Using anything else won’t help...
Knallkörper
21 Jun 2018 23:50
Let the other party come first. Prohibit everyone present from making any changes to the installation. Announce that you will consult your own expert afterwards. The contractor’s expert cannot override the standards; the functional defects are present, and they may also have a reputation to protect.
