ᐅ Working on a concrete ceiling
Created on: 24 Jul 2017 06:12
skyboy89
skyboy89
24 Jul 2017 06:12
We have finished the shell of our house and are now starting with the interior work. I have a question regarding our precast concrete ceilings. On the ground floor, we don’t want to install a dropped ceiling; the plasterer offered to plaster the ceilings there. In the basement, however, he said that wouldn’t be necessary.
Now my perhaps naive question: If I don’t plaster or drop the ceiling, how do I proceed with finishing it? Obviously, I need to fill the joints with filler, but then what? Is it simply painted afterwards?
How did you approach this?
Thanks for your help.
nelly190
24 Jul 2017 07:11
A friend of mine initially only wanted to fill the joints. However, he then decided to skim coat the entire ceiling with a fine finishing compound. The result is nearly perfect.
markus270324 Jul 2017 12:10
For our concrete ceiling on the ground floor, we only had the joints filled and then painted directly over that. The result is absolutely fine, but if someone wants a perfect finish, plastering is necessary.
But a basement ceiling? That definitely works. You will probably need to apply at least three coats of paint yourself for full coverage.
tomtom7924 Jul 2017 12:21
With a good quality paint, you don’t have to apply multiple coats. For concrete surfaces, however, please make sure to use a primer; otherwise, it will eventually start to peel off.
Alex85
24 Jul 2017 18:46
It definitely depends on the intended use. For simple storage rooms, for example, filling and painting is sufficient, but concrete needs to be primed.
