fragefüreinen2 May 2021 13:52Hello,
we are renovating a house from the 1950s and need to replace the water pipes. We are looking for a good system, preferably made of aluminum composite pipe or PVC.
Could you please tell me if this is a reasonable choice (or what questions to ask to determine if it’s suitable) and also recommend a system?
We are currently considering Uponor, Mepla, Marley DREMA, and JRG Sanipex. Are there any experiences with these?
Many thanks!
Many thanks!
hanghaus20002 May 2021 13:58If building new, make sure to consider the circulation system.
fragefüreinen2 May 2021 14:01hanghaus2000 schrieb:
If it's a new build, remember to consider the circulation.Yes, we are already looking into that. We're not entirely sure if it's really necessary, since it's mainly about preventing Legionella. The house is quite small, and the pipes are all within a very limited area. Is the choice of pipe dependent on the circulation decision?
hanghaus20002 May 2021 14:07I won’t comment on the quality of the pipes. I used copper and some kind of plastic piping. I’m not an expert in that area. I have water bills over 400 euros per year and don’t want to imagine how high they would be without circulation and a cistern.
fragefüreinen2 May 2021 14:14hanghaus2000 schrieb:
I won’t comment on the quality of the pipes. I installed copper and some kind of plastic piping. I’m not an expert there. I have water bills of over 400 euros per year and don’t want to imagine how much it would be without circulation and a cistern.I don’t quite understand that – circulation doesn’t actually reduce water consumption, does it? Do you mean a cistern that collects rainwater, filters it, and then supplies it to the house for use? Maybe you could briefly explain what you mean and how those things are related?
hanghaus20002 May 2021 15:57fragefüreinen schrieb:
I don’t quite understand – circulating water doesn’t reduce the amount of water used, right? Are you referring to a cistern that collects rainwater, which is then filtered and used in the house? Maybe you could briefly explain what you mean and how it all connects? The cistern is only for rainwater for the garden. You really need quite a bit of water for that.
