ᐅ Combine cistern and rainwater inspection chamber?
Created on: 3 Apr 2022 20:00
Seb_Opf
Good evening,
according to the zoning plan, a cistern must be built on the property. The drainage is carried out via a separate system.
So, two manholes and a cistern are required. From a technical point of view, is it possible to combine the rainwater inspection chamber and the cistern into a single structure to save some effort, or can I skip calling the authorities?
Thank you
WilderSueden
3 Apr 2022 22:30
By "combined cistern," I mean retention plus water reuse. Only part of the water is discharged from the cistern, not all of it. If you are going to install one anyway, it makes sense to size it a bit larger from the start.
Gartenfreund
4 Apr 2022 06:51
Here is the policy we follow.
Rainwater, also called stormwater, that is collected from roofs, driveways, etc., into a cistern and then used for garden irrigation or allowed to infiltrate on the property does not require any stormwater fees to be paid.
I had to look it up online because we have not paid stormwater fees for several years now.
The fee here is 1.36 euros per m² (10.8 sq ft) of sealed surface area per year.
If the cistern is connected to the sewer system, then half of that amount must be paid per m².
And as mentioned, if the cistern is not connected to the sewer but ensures that rainwater infiltrates exclusively on the own property, no fees are charged.
A meter is also not required.
If you want to use rainwater inside the house, a meter must be installed so that the rainwater, which then becomes treated water, can be properly billed.
Personally, I regret that I could only install a 4 m³ (140 cu ft) cistern underground.
If possible, choose a large cistern.
