ᐅ The door with a door closer no longer closes completely.
Created on: 19 Jul 2016 07:31
Sektionschef
Hello
My Method kitchen is now over a year old, and the following problem has appeared:
In a tall cabinet, there is a lower section with an 80cm (31.5 inches) hinged door equipped with two 153-degree Utrusta soft-close hinges.
When I try to close the door by a normal push, it now stops about 5cm (2 inches) short of closing fully.
I have already tried lubricating the hinges with WD40 oil, but it didn’t help. The door does not close completely on its own. When I remove the soft-close dampers, I notice the door moves very smoothly.
Could the problem be caused by the dampers?
I have also swapped the dampers with ones from another hinged door, but unfortunately, the result didn’t improve.
Does anyone have any advice?
Sektionschef
Sektionschef
10 Aug 2016 09:04
Hello
I have resolved the problem now!
When I removed the door, I noticed that the lower hinge was rubbing against the base plate of the cabinet.
I simply adjusted the hinge (or rather the mounting plate) slightly upwards using the adjustment screw. Now it no longer rubs, and the door closes completely with the dampers again.
Regards
Sektionschef
