ᐅ Does anyone use their KALLAX as a plant stand?
Created on: 6 Feb 2016 18:23
mariansan
mariansan
6 Feb 2016 18:23
I am currently exploring different ways to use an IKEA KALLAX shelf unit, especially regarding its use as a plant stand. My question is: does anyone actually use their KALLAX shelf as a plant stand and can share their experiences? I am interested in information about the load capacity of the shelves, potential damage caused by soil or water, as well as the best methods to safely accommodate plants there. Any advice on suitable plant containers or protective measures against moisture would also be very helpful.
Thanks in advance for your feedback!
nepeo66
6 Feb 2016 18:57
mariansan schrieb:
Does anyone actually use their KALLAX shelf as a plant stand and can share their experiences?
I have used the KALLAX as a plant stand. The shelves support the weight well. Important: use plant trays with saucers and avoid any water accumulation.
FAZAR
6 Feb 2016 20:12
mariansan schrieb:
Does anyone actually use their KALLAX shelf as a plant stand and can share their experiences? I’m interested in information about the load-bearing capacity of the shelves, possible damage from soil or water, and the best approach to safely accommodate plants there.
Basically, the KALLAX shelf is made of medium-density fiberboard and has a surface that appears sturdy but is not waterproof. This means that moisture can easily penetrate if the substrate is wet or if spills occur, which over time can lead to swelling or warping. Therefore, I recommend always using waterproof plant containers, ideally with a solid tray underneath to catch any water or soil.
Regarding load capacity: the shelves are stable enough for small to medium-sized plants; however, heavy pots with wet soil should be well distributed or placed across two compartments to prevent sagging. A useful approach is also to avoid placing plants directly on the shelves, but instead use a layer of durable, moisture-resistant material like acrylic sheets or thin plastic mats.
Do you already have a specific plant mix in mind? Some plants require more care and water than others, so you could tailor the choice of pots and protective measures accordingly.
One more note: if the shelf is in a bright, sunny room, UV rays can cause the surface to age faster, especially if water marks remain on the wood for extended periods.
Tause
7 Feb 2016 09:36
FAZAR schrieb:
The shelves are strong enough for small to medium-sized plants; however, heavy pots with wet soil should be well distributed or placed across two compartments to prevent sagging.
This is an important point. However, when using KALLAX as a plant stand, it is also worth considering the long-term effects. KALLAX is not specifically designed for use in damp areas or as plant furniture – this also applies to the materials and the support beams.
FAZAR schrieb:
important: waterproof plant containers and solid drip trays
Exactly. In addition, I would like to ask if anyone has concrete experience with effective ways to prevent moisture damage. Is it practical to cover the entire shelf surface with a waterproof mat, or is it better to protect each compartment individually? How does this work in everyday use regarding maintenance and watering?
Furthermore, I am interested to know if anyone has implemented structural reinforcement of the shelves (e.g., additional cross braces) to increase load capacity for larger plants.
In my opinion, the discussion here should also critically address whether KALLAX as an affordable solution is practical in the long run or if alternative furniture options are more suitable.
JAPLO
7 Feb 2016 11:02
Tause schrieb:
whether KALLAX as an apparently inexpensive solution is practical in the long run or whether alternative furniture is better suited.
As someone who places plants on furniture, I can say from experience that KALLAX can work as a plant shelf if you consistently apply protective measures. These include waterproof coasters, regularly wiping off moisture, and placing a water-resistant board or sheet under the plants.
There is also the option to reinforce the back panels or cover the shelves with cut-to-size waterproof material. Adding an extra crossbar is also possible with some DIY skills and increases the weight capacity.
However, I would recommend, especially for delicate or expensive plants, not to rely solely on KALLAX but rather use it as a complement to other sturdier solutions. Also, consider furniture designed specifically for plants and damp environments. Still, KALLAX is a flexible and homely system, and with the right precautions, it can work well as a plant shelf.
