Gerd&Jolanthe17 Dec 2018 22:17Hello,
I have a question about power outlets and the best position to install them.
They are usually installed at a height of 30cm (12 inches) above the finished floor, but what distance should be kept from the wall or from a corner? Should it be 15cm (6 inches) centered, like with door frames, or should it be more?
Thank you very much
Thank you very much
Gerd&Jolanthe17 Dec 2018 22:20I can place them wherever I want? I thought there was usually a guideline or a recommended standard.
Bookstar schrieb:
As you wish, there is no requirementI agree, it’s purely a matter of coordination. However, the electrician should be able to install the box comfortably 😉
There are so-called installation zones according to DIN standards. Just look them up online. They should be observed, but in my opinion, it is not absolutely necessary. However, as an electrician, I would definitely have a lawyer draft and countersign any exceptions if the client requests deviations ;-)
