I am considering buying a dehumidifier but am unsure if it is truly worthwhile. In which situations are these devices genuinely useful, and when is it better to avoid using them? On one hand, I often hear that dehumidifiers can be a good solution for moisture problems in basements or poorly ventilated rooms to help prevent mold growth. On the other hand, I wonder if the energy consumption really justifies these benefits, especially when the humidity levels are not extremely high. Are there alternatives that use less energy, or is a dehumidifier the best option in certain cases? What are your experiences and tips for using these devices?
There is a ventilation control system for basements that calculates from the absolute humidity levels inside and outside when ventilating will reduce the humidity in the basement. I have one myself, and the basement no longer smells musty.
We use a dehumidifier in the basement when we hang laundry there, which otherwise takes about 3 days to dry depending on the temperature, or when after heavy rain there is a puddle of water rising naturally from the floor, so it dries faster again (the water rising is not a problem in itself. It’s an old house with a basement that wasn’t really designed to be dry).
nordanney30 Jan 2025 15:51Baumer schrieb:
In which situations are such devices truly useful,When the humidity is too high for the specific situation. There are many different scenarios where they can be helpful, for example: - constantly damp basements = preventing mold
- introducing high humidity into rooms with cold walls (drying laundry in the basement, drying laundry in the living room of an older building)
- high humidity in rooms – often in older buildings, to avoid mold
and so on.
Baumer schrieb:
Are there perhaps alternatives that use less energy?Initially, a dehumidifier does not necessarily consume a lot of energy. Depending on the situation, there may be other options such as mechanical ventilation, skirting board heating, insulation… Baumer schrieb:
What are your experiences and tips for using these devices?I have a portable air conditioner for summer emergencies. It can also dehumidify. I rarely use it in the basement because adding insulation to the basement ceiling lowered the temperature there by several degrees, and at certain times in summer the humidity rises enough for the walls to become damp. The advantage for me is that I can also use it as a real air conditioner in the living area by simply connecting the exhaust to the decentralized fans.
A quick question about basement dehumidification.
My neighbor installed a greywater heat pump in his basement. It uses the "warm" basement air as an energy source and apparently also dries out the basement. When I asked if this doesn’t cause the basement to cool down significantly, he said it’s only about three degrees cooler.
Is it possible to kill two birds with one stone using a solution like this?
