ᐅ Covering and Cladding for Formwork Block Walls – What Are the Options?
Created on: 11 Mar 2025 10:56
Stefan2.84
I want to attach coping slabs on top of our walls (see pictures) and improve the overall appearance of the walls.
The standard coping slabs in gray/anthracite are easy to install but not very attractive visually. Does anyone have a nice alternative idea?
I would also like to plaster and paint the walls themselves. Has anyone had experience with this? Or are there other options as alternatives?
Thanks and best regards,
Stefan
Außenansicht eines Hauses mit Holzlattenzaun, erhöhter Terrasse, Gartenschlauch und Gras.
Garten mit Steinmauer, Treppe rechts, alte blaue Bank, Pflanzen und weißer Briefkasten.
Peter_H_
11 Mar 2025 15:48
If it is ensured that the wall will not be exposed to moisture from the back over time, I would apply a layer of plastic-reinforced filler, for example "gima xxl," and texture it with a notched trowel with 5mm (0.2 inch) teeth. Then apply a base coat plaster with reinforcing mesh on top. Finish by painting the whole surface with a suitable facade paint. You can then connect it directly to the house. This seems necessary, but if the wall does draw moisture from the back, the coating will eventually delaminate. In that case, the only solution is to install battens and cladding to ensure ventilation behind the facade.
Nida35a11 Mar 2025 19:53
One option that comes to mind is colored pebble dash plaster. It comes in various colors and can be applied yourself directly from the bucket. It is also resistant to moisture as a base coat and holds up well against frost and strong sunlight.
Arauki11
11 Mar 2025 20:38
Stefan2.84 schrieb:
"Wood belongs in the stove," said my colleague.
It’s clear you’re surrounded by experts. Ultimately, it’s up to you which advice you choose to follow. Depending on your craftsmanship skills, it can be quite tricky to neatly finish the cladding on steps or transitions, as well as where it touches the ground or around the base of the fence. I’d be interested to see a photo after the connections are made, as well as the practical approach your professional suggests for executing these areas cleanly and attractively.
Z
Zubi123
12 Mar 2025 07:56
Nida35a schrieb:
I immediately think of colored stone plaster,
available in various colors and easy to apply yourself straight from the bucket. It is also moisture-resistant as a base coat and holds up well against frost and strong sunlight.
I have a similar project for a small base of a 20m (65.6 ft) wall. Colored stone plaster sounds like a great tip! Thanks 🙂
wiltshire
12 Mar 2025 09:13
It might not fit your style, but some graffiti looks spectacularly good.
SoL
12 Mar 2025 09:34
I suggest fiber cement boards – they can be made to look like wood, are durable, and low maintenance...
