ᐅ Concrete inside the ducts of the mechanical ventilation system with heat recovery
Created on: 22 Sep 2016 16:19
Lile08
Hello!
We have a huge problem right now.
A few weeks ago, our installer placed the ductwork for the mechanical ventilation system between the steel layers of the ground floor ceiling.
The next day, the concrete ceiling was poured with cast-in-place concrete.
Today, when the installer wanted to connect the ducts and so on, it was noticed that concrete had flowed into two of the ducts.
Now the question is how this could have happened.
Could the ducts have been damaged by the concrete workers, or are they sturdy enough that this is unlikely?
Otherwise, the only possibility would be that the duct connections didn’t hold and came apart.
Do you have any idea how something like this might happen?
And above all, can someone tell me what can be done now to fix it?
Should the ducts inside the screed be reinstalled?
It would be great if someone experienced could give me a few tips so we don’t look clueless at the appointment with the installer tomorrow. Of course, everyone will probably try to avoid taking responsibility for the damage to avoid paying for it...
Bieber0815
27 Sep 2016 07:18
And does that fit into your floor construction?
Lile08
27 Sep 2016 09:36
Yes, that fits.
These are special flat ducts that are embedded in the screed.
Mycraft27 Sep 2016 12:57
Most likely not in the screed but below it, within the insulation.
Bieber0815
27 Sep 2016 22:27
The floor structure was previously too high. (Not technically too high, but just too expensive.)
I’m really curious about the details. It sounds a bit too simple to me, and I can hardly believe such a significant change in the construction method is easily possible.
In any case, will the affected pipes be completely relaid along their entire length? Are there intersections with other lines that are already installed on the raw ceiling slab?
Edit: Embedding them in the screed would probably not be technically correct (minimum coverage and all).
bernie
28 Sep 2016 09:49
The rectangular ducts must be installed on the raw concrete --> then insulation --> then screed
(that is, not embedded IN the screed)
Lile08
1 Oct 2016 19:45
Of course, the flat ducts are installed below the screed, not inside the screed.
There are 2 pipes that need to be newly installed; all the others are fine.
According to the ventilation installer, it fits perfectly with the floor structure.
